2013 acting different
for instance.... if I right click on an xref I don't get the option to "open xref"....as well as "open block editor".... is there a switch for these options somewhere? :?
Right click shortcut menus.
wow...you had me all excited but mine is already checked. :( this is strange. I'm getting a new machine soon which will require reloading. Curious if that fixes it.
thanks for your reply tho!
Try setting your right click customization options like mine, and you should be good to go.
You should check in OPTIONS on the PROFILE tab, and make sure that you are running the PROFILE which you think you are.
  • 2 weeks later...
got new machine (its a hoss!) and now MEP 2103 is fatal erroring when I start MEP... was running fine and now is consistant. I've repaired...uninstalled...reinstalled...tried to defrag...etc etc... but to no avail. I'm going to try to re-re-re-re load it this weekend. Ended up loading architecture as I had a deadline...
