Print_Master Posted August 16, 2012 Posted August 16, 2012 I am trying to make 2 different size cirlces into to on Solid object. One circle is 20 in diameter and the other is 50 in diameter. I was wondering what the command was. Thanks for all the help in advance:) Quote
ReMark Posted August 16, 2012 Posted August 16, 2012 After you have given them a height are you going to union them in some manner so there are one solid model? Quote
Dadgad Posted August 16, 2012 Posted August 16, 2012 Use the LOFT command, in order to make them into one 3D solid entity. They will need to be on different planes, so you will need to give them different Z axis values, which you can do with PROPERTIES, or by using the 3DMOVE command (among numerous others). Quote
