How to create a lisp program displaying coordinates
Nearly got it!!!! Thanks!!!
Last thing..... Need an arrow pointing to the point which the coordinate states
  • Replies 49
  • bharthts01
    24
  • Lee Mac
    11
  • MSasu
    7
  • Tiger
    3
It is good to re-invent the wheel every now and again, but for the more idle amongst us, this thread seemed to cover the current topic several years ago. :D
How about simply:
(defun c:dimo ( / p )
   (while (setq p (getpoint "\nSpecify Point <Exit>: "))
       (command "_.dimordinate" "_non" p "_T" (strcat "X=" (rtos (car p)) "\\XY=" (rtos (cadr p))) "\\")
How about simply:
Is that the full code?
Is that the full code I.e
Copy and paste that into notepad? Or is there more to that?
(defun c:ne( / oldOsmode e-x n-y ne1 prmt tx-ht vx vy x-ht xx yy )
(defun go_ne()
 ;(setvar "luprec" 2)
 (setq prmt (strcat "Enter TEXT HEIGHT<" (rtos tx-ht) ">: "))
 (princ prmt)
 (setq x-ht (getreal))
 (if (= x-ht nil)
  (setq x-ht tx-ht)
 (setq tx-ht x-ht)
 (setq e-x (car ne1))
 (setq xx (rtos e-x 2 0))
 (setq n-y (cadr ne1))
 (setq yy (rtos n-y 2 0))
 (tx-f)
(defun tx-f()
 (setq vx (strcat " E " xx))
 (setq vy (strcat " N " yy))
 (command "_.TEXT" "_J" "_ML" ne1 x-ht 0.0 (strcat vx " / " vy))
(setq tx-ht 0.5)
(setq oldOsmode (getvar "OSMODE"))
(setvar "osmode" 427)
(setq ne1 (getpoint "\nPick point..."))
(setvar "osmode" 0)
(if (/= ne1 nil)
 (go_ne)
 (princ "\nInvalid Location !")
(setvar "OSMODE" oldOsmode)
This is the code I'm using.
This is what it looks like (highlighted with the red bubble).
I'm after one last thing, which is the 'line/point' which the coordinate is stating.
As shown on the left.
Did you try my code?
What command is it?
Right thanks for that. Would be possible for it to show only 9 digits and increase the spacing between x and y?
Being a bit picky here, but would look neater if it all was on 1 line. X 430254889 Y 434123122 (random numbers)
My program simply uses the DimOrdinate command with a custom text string.
The string is constructed using the following expression:
The "\\X" places the subsequent text beneath the dimordinate dimension line.
The units and precision are controlled by your settings of LUNITS & LUPREC; MSasu has already shown you how to modify rtos expressions.
I've no idea what you just wrote.
Possible to get the coordinates to 9 digits please?
Edit: And make them all on 1 line?
Thanks for the Code Btw Lee Mac, but I'm quite happy with this one. It's a lot 'neater' just need the 'line' adding to it that's all.
(defun go_ne()
 (princ prmt)
 (if (= x-ht nil)
  (setq x-ht tx-ht)
 (setq tx-ht x-ht)
 (tx-f)
(defun tx-f()
(setq tx-ht 0.5)
(setvar "osmode" 0)
(if (/= ne1 nil)
 (go_ne)
I would suggest you carefully read it again and at least put a little effort into trying to understand what the code is doing, instead of expecting everything to be handed to you on a plate.
I have read it, I don't follow you. No need to get big headed.
Which parts specifically do you not understand?
If you do not understand my explanations, I would expect you to ask questions for clarification, not bluntly dismiss the explanation out of hand.
I'll choose to ignore the immature comment while you reconsider which one of us is asking for help.
