igones Posted August 21, 2012 Share Posted August 21, 2012 Hi everyone, Look at the picture. How can I scale the line to show the dashes? If a draw a bigger rectangle the dashes shows up... Is it possible to set a measure for each space? What can I do? I'm drawing in Meters 1 = 1m. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted August 21, 2012 Share Posted August 21, 2012 Adjust LTSCALE to suit. Are you using linetypes from acadiso.lin? Quote Link to comment Share on other sites More sharing options...
igones Posted August 21, 2012 Author Share Posted August 21, 2012 Yep. acadiso.lin I'll try it now. Thanks! Is it possible for me to create a linetype? Example: . - . - . and set the distance between dot and dash? Thanks! Edit - LTscale is what i was looking for!! =))) Quote Link to comment Share on other sites More sharing options...
SLW210 Posted August 21, 2012 Share Posted August 21, 2012 Yes, Plenty on CADTutor for creating custom linetypes. Quote Link to comment Share on other sites More sharing options...
igones Posted August 21, 2012 Author Share Posted August 21, 2012 Thanks! I'm gonna search! =] Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 21, 2012 Share Posted August 21, 2012 Options for creating custom linetypes. http://www.cadtutor.net/forum/showthread.php?27454-Options-for-creating-linetypes.&highlight=custom+linetype Quote Link to comment Share on other sites More sharing options...
eldon Posted August 22, 2012 Share Posted August 22, 2012 I usually use the acad.lin linetypes although I draw in metre units. Those line types were written with simple scaling for the dashes and spaces, and are much easier to predict for scaling. Quote Link to comment Share on other sites More sharing options...
igones Posted August 22, 2012 Author Share Posted August 22, 2012 Thanks Remark. I didn't know about that! Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 22, 2012 Share Posted August 22, 2012 You're entirely welcomed. Quote Link to comment Share on other sites More sharing options...
mondaymonkey9 Posted November 23, 2012 Share Posted November 23, 2012 If you don't want to change the line type scale for every line, you can click on the desired line you want to change, type in "PR" or "PROPERTIES" or right click --> properties, find the line type scale and play around the with numbers there. Hope that helps. Quote Link to comment Share on other sites More sharing options...
