Is it possible to bend the pipe?!
Hi,
I was wondering if it is possible to bend the pipe while drawing.
I don't mean using elbows or parts, just drawing the pipe in arc?
At the moment I have created some custom parts, 4xD bends to represent my layout. Just curious to know if it is possible?
Thanks
It would be better to create these fittings with the proper bend radius, but to get away with something you can create an arc or polyline, select it, right-click > Convert To > Flex Pipe. It will give you an option to make it a braided hose or something if I remember correctly. It's not perfect but it works.
Thanks for reply
I will try it, and compare it with my fittings
Thanks again for your help
Dont use MEP but if you Extrude a circle along a "PATH" it will give a tube bend, this may be helpfull.
