totalblackout Posted November 5, 2008 Posted November 5, 2008 I have a drawing with about 10 dynamic blocks in it and when i go try to WBLOCK each DB its not working correctly. Any ideas on why this is happening thanks Quote
totalblackout Posted November 5, 2008 Author Posted November 5, 2008 i figured out the earlier problem. Here is a new one. im going to attach the file. What im trying to do is have separate markers on each side of the bubble and i am trying to use the Visibility parameter. but everytime i use it think i got it i close block editor and then go to try and switch from one state to the other it comes out all messed up and i cannot get it to work. i attached the file. Example.dwg Quote
totalblackout Posted November 5, 2008 Author Posted November 5, 2008 anyone? cause i cant get this to work without being screwed up Quote
totalblackout Posted November 5, 2008 Author Posted November 5, 2008 i got it . apparently when you use visibility states with attributes that are the same it makes everything go all crazy Quote
