Daniel C Posted August 28, 2012 Posted August 28, 2012 Hi All Firstly, thank you for providing a fantastic resource for all ACAD users, of all abilities. I have a question which sadly the search function hasn't helped with. I would like to know if it is possible to turn a solid fill area into a transparent appearance. This is in a 2D drawing. Many Thanks Daniel Quote
Dadgad Posted August 28, 2012 Posted August 28, 2012 Hello Daniel, welcome to the forum, that is nice of you to say. I rarely have any use for transparency, and just gave it a shot, attempting to change the transparency from BY LAYER to different numeric values, and didn't have any luck. Perhaps there IS a way, and likely somebody else may know one and be able to help you. Quote
ReMark Posted August 28, 2012 Posted August 28, 2012 Isn't there a "transparency" property for objects in Civil 3D? Making a "solid" fill "transparent". That's my chuckle for the day. Thanks. Quote
ReMark Posted August 28, 2012 Posted August 28, 2012 Dadgad: Object Transparency Property. Introduced in 2011. http://autodesk.blogs.com/between_the_lines/2010/03/autocad-2011-feature-tips-tricks-transparency.html Quote
Daniel C Posted August 28, 2012 Author Posted August 28, 2012 Yeah, what my objective is would be to fill an area with a transparent colour, not a solid colour, hopefully that is a bit more understandable. Quote
ReMark Posted August 28, 2012 Posted August 28, 2012 Did you see the link I posted for Dadgad? Not sure if it applies to your situation. Quote
ReMark Posted August 28, 2012 Posted August 28, 2012 Have you seen this by Dana Probert ( BIM on the Rocks) Civil 3D 2011: Using AutoCAD 2011 Layer Transparency for Civil 3D Objects One of the new features for AutoCAD 2011 is the ability to make a layer transparent. Since Civil 3D 2011 is built on AutoCAD 2011, you can take advantage of this new tool. Think of all of that hatching we’ve done over the years- how awesome to make it transparent! It should work for solid fills yes? Quote
Daniel C Posted August 28, 2012 Author Posted August 28, 2012 Thank you very much for the link ReMark. I appreciate you taking the time, and yes it was what I have been looking for. Many Thanks. Quote
Dadgad Posted August 28, 2012 Posted August 28, 2012 Dadgad: Object Transparency Property. Introduced in 2011. http://autodesk.blogs.com/between_the_lines/2010/03/autocad-2011-feature-tips-tricks-transparency.html Thanks ReMark, I've seen it around, just not had any real use for it, although I am a big fan of the X-RAY visualstyle. When I tried this a few minutes ago I changed the transparency of a solid from BY LAYER to numbers ranging up to 90, but couldn't see any change. Is it meant to display too, not just for printing, right? I think i have turned it off globally in my SYSVDLG. Now I got it working, had to change my HPTRANSPARENCY variable setting. Quote
