above image is the problem occured on my autocad everytime i am opening a file or a new sheet, it occurs every 2-3 minutes while working on it.
i know most of the members here knows how to solve it, pls help thanks.
When did the problem first start happening?
Have you made any changes to your system (hardware or software)?
What have you done to troubleshoot the problem so far?
i didnt do any action for this, it started two weeks ago. i didnt change anything, suddenly it became like that.
Are you current with all updates?
Do you work with drawings that come from outside the company like from a contractor or client?
Have you run a virus scan lately?
You will most likely need to completely uninstall and reinstall SEE THIS. Sounds like a Windows Update issue or something with the registry. What antivirus program are you using?
