HI!! i need help!! TT_TT
when i try to open acad... it always send me a message saying fatal error... i have the list of the errors....
FATAL ERROR:  Unhandled Access Violation Writing 0xdf150e00 Exception at df150e00h
06/12/2012 at 14:27:12.083  Drawing: Drawing1.dwg
FATAL ERROR:  Unhandled Access Violation Writing 0xdffc0e00 Exception at dffc0e00h
06/12/2012 at 14:34:31.734  Drawing: Drawing1.dwg
FATAL ERROR:  Unhandled Access Violation Writing 0xec030e00 Exception at ec030e00h
06/12/2012 at 14:41:11.620  Drawing: Drawing1.dwg
FATAL ERROR:  Unhandled Access Violation Writing 0xdfb30e00 Exception at dfb30e00h
06/12/2012 at 14:48:23.465  Drawing: Drawing1.dwg
FATAL ERROR:  Unhandled Access Violation Reading 0x0010 Exception at f39caf2dh
08/14/2012 at 17:17:59.262  Drawing: Drawing1.dwg
FATAL ERROR:  Unhandled Access Violation Reading 0x0010 Exception at f533af2dh
08/14/2012 at 17:18:55.659  Drawing: Drawing1.dwg
FATAL ERROR:  Unhandled Access Violation Reading 0x0010 Exception at f616af2dh
08/14/2012 at 20:53:25.326  Drawing: Drawing1.dwg
FATAL ERROR:  Unhandled Access Violation Reading 0x288c5b60 Exception at f616d87fh
08/14/2012 at 20:53:26.324  Drawing: Drawing1.dwg
08/14/2012 at 20:53:27.026  Drawing: Drawing1.dwg
FATAL ERROR:  Unhandled Access Violation Reading 0x28933ec0 Exception at f933d87fh
08/14/2012 at 21:03:54.526  Drawing: Drawing1.dwg
FATAL ERROR:  Unhandled Access Violation Reading 0x286f3530 Exception at f32ad87fh
08/14/2012 at 22:25:54.032  Drawing: Drawing1.dwg
FATAL ERROR:  Unhandled Access Violation Reading 0x0010 Exception at f267af2dh
08/15/2012 at 01:39:59.731  Drawing: Drawing1.dwg
FATAL ERROR:  Unhandled Access Violation Reading 0x0010 Exception at f287af2dh
08/15/2012 at 01:40:16.448  Drawing: Drawing1.dwg
FATAL ERROR:  Unhandled Access Violation Reading 0x0010 Exception at f26daf2dh
08/15/2012 at 01:40:54.255  Drawing: Drawing1.dwg
FATAL ERROR:  Unhandled Access Violation Reading 0x0010 Exception at f5bbaf2dh
08/15/2012 at 02:02:42.250  Drawing: Drawing1.dwg
FATAL ERROR:  Unhandled Access Violation Reading 0x0010 Exception at f95daf2dh
08/15/2012 at 02:03:08.286  Drawing: Drawing1.dwg
FATAL ERROR:  Unhandled Access Violation Reading 0x0010 Exception at f899af2dh
08/16/2012 at 21:58:08.014  Drawing: Drawing1.dwg
08/16/2012 at 21:58:14.063  Drawing: Drawing1.dwg
FATAL ERROR:  Unhandled Access Violation Reading 0x0010 Exception at f8c5af2dh
08/16/2012 at 21:59:26.969  Drawing: Drawing1.dwg
FATAL ERROR:  Unhandled Access Violation Reading 0x0010 Exception at f8d4af2dh
08/16/2012 at 22:07:20.487  Drawing: Drawing1.dwg
FATAL ERROR:  Unhandled Access Violation Reading 0x0010 Exception at f56caf2dh
08/17/2012 at 00:15:53.008  Drawing: Drawing1.dwg
FATAL ERROR:  Unhandled Access Violation Reading 0x0010 Exception at f8b2af2dh
08/17/2012 at 02:30:05.281  Drawing: Drawing1.dwg
FATAL ERROR:  Unhandled Access Violation Reading 0x27a37fc0 Exception at f55fd87fh
08/17/2012 at 02:37:39.213  Drawing: Drawing1.dwg
FATAL ERROR:  Unhandled Access Violation Reading 0x28098160 Exception at f537d87fh
08/17/2012 at 02:38:46.807  Drawing: Drawing1.dwg
FATAL ERROR:  Unhandled Access Violation Reading 0x0010 Exception at f55faf2dh
08/17/2012 at 02:40:18.749  Drawing: Drawing1.dwg
FATAL ERROR:  Unhandled Access Violation Reading 0x0010 Exception at f580af2dh
08/17/2012 at 02:40:47.553  Drawing: Drawing1.dwg
FATAL ERROR:  Unhandled Access Violation Reading 0x0010 Exception at f8baaf2dh
08/17/2012 at 02:55:42.346  Drawing: Drawing1.dwg
FATAL ERROR:  Unhandled Access Violation Reading 0x0010 Exception at f691af2dh
08/18/2012 at 17:05:38.460  Drawing: Drawing1.dwg
FATAL ERROR:  Unhandled Access Violation Reading 0x0010 Exception at f5c3af2dh
08/19/2012 at 18:22:02.704  Drawing: Drawing1.dwg
FATAL ERROR:  Unhandled Access Violation Reading 0x0010 Exception at f312af2dh
08/20/2012 at 16:02:17.695  Drawing: Drawing1.dwg
08/20/2012 at 16:02:19.649  Drawing: Drawing1.dwg
08/20/2012 at 16:04:41.456  Drawing: Drawing1.dwg
FATAL ERROR:  Unhandled Access Violation Reading 0x28808290 Exception at f312d87fh
08/20/2012 at 16:08:20.323  Drawing: Drawing1.dwg
FATAL ERROR:  Unhandled Access Violation Reading 0x0010 Exception at f793af2dh
08/30/2012 at 03:28:24.171  Drawing: Drawing1.dwg
what can i do? o.O?! thx
Edited by Tiger
added quote tags
Did you try a REPAIR or a REINSTALL?
What are the specs on your computer?
What OS are you running?
Edited by ReMark
You have been doing this since June? Has it ever run properly? That "list" is all the same error. The only difference is the physical memory address the program is trying to access on each run. The memory location may or may not normally change with each execution since programs are alotted memory space by the OS on a first come first served basis. This one is trying to run outside the normal bounds of allowable memory space. In other words, it is not following instructions from the OS. This tells me there is something wrong or missing with your program or something missing from the install.
Is this a licensed copy of AutoCad? Did the install run without errors? Is *.net installed?
  • 2 weeks later...
i have already tried to repair and reinstall the acad... but it still having errors....
my pc basic information are:
W. VISTA
processor: adm turion™X2ultra dual-core mobile ZM-82 2.20 GHz
memory(ram): 4GB
System type: 64-bit OS
i think everything is ok... everything have to work properly... ohh and the first time that i install the acad... it was working properly... but the errors appears since june...
For one, you are running AutoCAD 2013 on Vista 64 which is unsupported.
Did you COMPLETELY UNINSTALL ALL AUTODESK PRODUCTS as per the link I posted?
Any messages when you try to reinstall?
What .NET framework version(s) are installed?
