Reinaldo Camacho Posted February 21, 2020 Posted February 21, 2020 Do anyone in this Forum can recommend me a great book to learn how to create my own Visual lisp Routines? I have seen a lot of books on the internet and Amazon but I would like to get a good one from any of you that already knows the programming language. I have a low-level skill as a programmer but I have read a lot and I understand a lot of things now. Thank you in advance. Quote
BIGAL Posted February 22, 2020 Posted February 22, 2020 Try Kindle some good books and very cheap can copy code from book that's important. I downloaded 4 Quote
FriesL Posted April 29, 2020 Posted April 29, 2020 On 20/07/2016 at 17:32, MURAl_KMD said: hi Lee Mac Thanks to you for all codes , which helps me a lot (repeat (setq idx (sslength sel)) (LM:burstnested (vlax-ename->vla-object (ssname sel (setq idx (1- idx))))) ) The above code modified in NestedBurstV1-0.lsp of Lee Mac (repeat (setq idx (sslength sel)) (LM:ApplytoBlockObjects (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))) (vla-get-effectivename (vlax-ename->vla-object (ssname sel (setq idx (1- idx))))) 'LM:burstnested ) ) This works for me so far , Hi, Sorry for digging up this old thread. Currently in need to burst attribute blocks or nested attributes blocks to a normal block with all field input intact. is there a way to do this? Quote
seawind Posted March 13, 2021 Posted March 13, 2021 If it isnt a big problem i would someone to modify the lisp so it can explode nusted mtexts to texts without exploding the primary block. Quote
Mori Posted April 4 Posted April 4 Hi all, is it possible to tackle removing all nested blocks the other way around? how can i ask autocad to explode all blocks Only if they embed at least one more blocks inside them? i want my file to only have normal blocks and not any nested block inside it. Quote
