anp2012 Posted September 5, 2012 Posted September 5, 2012 I usually come across this situation where i have to convert PDF to DWG. now i do it with underlay and trace it approx. Is there any converter for this purpose? I want a software to convert PDF to DWG/DXF with relative amount of accuracy. Thanks for help in advance Quote
MSasu Posted September 5, 2012 Posted September 5, 2012 There were many discussions in the past on this matter; here you can find an example. Please do a search on the Forum for other. If I recall well, the general conclusion was that the results of such conversion isn't very satisfying, so the trace over solution is the recommended one. Quote
SLW210 Posted September 5, 2012 Posted September 5, 2012 Try a program called VectPDF it is a LISP that uses PStoEdit to convert PDF to DXF and creates text in AutoCAD. Needs to be a vector PDF. Otherwise you need a Raster to Vector converter. As far as the results from conversions being satisfactory or not, it depends on your needs. Quote
JosephSpence Posted November 20, 2012 Posted November 20, 2012 AutoCAD 2012 supports PDF attachments, but I also need to convert my PDF files to DWG or DXF format. I have tried some software to do the conversion - Adobe Illustrator, Any PDF to DWG Converter, Aide PDF to DXF Converter and VectPDF. Illustrator, Any PDF to DWG Converter, Aide PDF to DXF Converter are not free and VectPDF is freeware. VectPDF converts raster image to vector DXF format and it saves my time. Quote
elizabethvictoria Posted March 21, 2014 Posted March 21, 2014 Do you know if this will work with AutoCAD LT? Try a program called VectPDF it is a LISP that uses PStoEdit to convert PDF to DXF and creates text in AutoCAD. Needs to be a vector PDF. Otherwise you need a Raster to Vector converter. As far as the results from conversions being satisfactory or not, it depends on your needs. Quote
Dana W Posted March 21, 2014 Posted March 21, 2014 Do you know if this will work with AutoCAD LT?It won't work. You cannot run lisp code in LT. It's one of the things you didn't buy when you bought LT, just like me. Quote
