Hi all,
I have recently starting using dimensions lines with overwritten text to label items (as it is a quick way to label multiple identical items).
What I'd like to add is a mark (like an architectural tick/oblique) each time the dimension line intersects one of the items.
Is this possible?
Thanks
I suggest you consider using a MULTILEADER instead, there are numerous options when creating a new style,
look through them all, you'll see how useful they are, and this should be quite simple to do.
As a Dimension you will not be able to display the tick at the attachment end of the extension line. :)
I'm afraid I dont have mulitleaders available.
Not sure that would do what I want though, I'd like just one label for each run of objects, but with the oblique on each object also
You could do the same thing with a LEADER style, you must have those.
Sorry, I have never used LT.
The reason I am suggesting either Multileaders or Leaders is because then when you add the specified
icon or ARROW style to it, it will be where you want it to be, unlike with a dimension arrow or architectural tick, or whatever.
Start the LEADER command, then enter S for settings, and you can define your style there.
Did you check to see if you have a MULTILEADER toolbar available?
They are much more customizable, and I find it hard to believe that
LT wouldn't have them.
Edited by Dadgad
Do you have an example of what you wish to accomplish?
