Multiple Visibility Parameters
nacirpl
Hello,
I found this to interesting and proven on having more than 1 Visibility Parameter.
The below link redirects to a page of 2 guys work Andrey Lazebny and Nikolay Poleshchuk.
http://www.private.peterlink.ru/poleshchuk/cad/2009/tainypod12e.htm
Their block works perfectly, unfortunatelly I was unable to repeat their work.
I can't create more than 1 Visibility Parameter on either 2007 or 2012 AutoCAD.
From some reason it does not want to use the defun commands. CAD loads it with no errors, both lsp files but once I'm trying to run those commands (visibility_add or move-parameter) it just gives me Unknown Command error.
I'm not good in Auto LISP, but does anyone knows how to make this piece of art to work ?
Maybe it's a AutoCAD version issue, but like described earlier I was doing the test on both 2007 and 2012 ver.
  • 1 month later...
Hi, some time ago i had this problem to.
Link below helped me to add more than one visibility to the block
http://forums.autodesk.com/t5/Dynamic-Blocks/You-gotta-try-visibility-add-eng-v1-1/m-p/2521041/highlight/true#M10102+
but unfortunatelly at the end i resigned of this because each visibility-parameter much increase size of my drawing file.
HPH
