srichang Posted September 12, 2012 Posted September 12, 2012 Please tell me the best way to get high resolution PDF and JPEG images from Autocad...everything I do is either Fuzzy ( in JPEG) or gets thick and blotchy ( in PDF) Quote
Tiger Posted September 12, 2012 Posted September 12, 2012 There are several PDF printers that you can try, such as CutePDF or PDFCreator. Lately I have used the on-board PDF printer that comes with AutoCAD and that works perfectly. If your lines get thick on the PDF, it could be the CTB-files fault, if you are using one of those? Or you have too big line weight on your lines? As for JPG, I have no good idea there. Sorry. Quote
BIGAL Posted September 13, 2012 Posted September 13, 2012 If you want to paste jpg into word etc try WMFOUT it works way better. Pretty sure jpg's are 200 dpi and you can not change, rendering allows dpi changing but not just say web-jpg, you can change Tiff resolution . Quote
