What is the proper way to input architectial lines into site plan drawing?
very vague...
How do you mean architectural lines?
Sorry,
I am in architect units and trying use the correct commands to enter line cordinates and having no success
I assume you are using metric.
Are you trying to layout lot boundaries?
Armenta, it would help us a lot if you could elaborate on your intentions. help us help you.
just simply saying inches and boundaries looks like an effortless attempt to undertand your questions
Sorry fellas, I am trying to create a site plan and havent mastered the cordinate system of Degrees, Hours & Minutes commands...just need a baseline direction
I am also struggling with bearings and distance coordinates
I believe the way autocad wants you to input it is very user unfriendly
@116.77
I have a lisp routine that I got off this site
it sepparates the input
instead of the one line above, type
116.77
86
32
54
and it will draw the line
type bd to start
;Tip1741: BD.LSP Bearing/Distance lines ©2001, Joon Hong $50 Bonus Winner
(defun C:BD ()
(setvar "cmdecho" 0)
(initget 1)
(setq PT (getpoint "\nPick a starting point: "))
(initget 1 "NE NW SE SW")
(setq BR (getkword "\nPick bearing (NE/NW/SE/SW): "))
(setq OPT (strcase BR))
(initget 1)
(setq LEN (getreal "\nType the length: "))
(setq DEG (getstring "\nType the degree: ")
minx (getstring "\nType the minute: ")
SEC (getstring "\nType the second: "))
(if (= DEG "")
(setq DEG "0"))
(if (= minx "")
(setq minx "0"))
(if (= SEC "")
(setq SEC "0"))
(cond ((= "SW" OPT)
(setvar "angbase" (cvunit 270 "degree" "radian"))
(setvar "angdir" 1))
((= "SE" OPT)
(setvar "angdir" 0))
((= "NW" OPT)
(setvar "angbase" (cvunit 90 "degree" "radian"))
((= "NE" OPT)
(setvar "angdir" 1)))
(command "line" PT (strcat "@" (rtos LEN) "
(setvar "angbase" 0)
(setvar "angdir" 0)
(setvar "cmdecho" 1)
(princ))
(princ "\nType 'BD' to draw lines with bearings")
