Hi,
I am having trouble plotting to scale, I have a large drawing which is set up in metres so I understand I need to scale up the figure by multiplying by 1000 but the problem is: I set up my paper at A1 and then zoom and adjust to an acceptable scale which turns out to be 1:850 by typing in .85xp, once drawing is printed to scale it is not 1:850 but 1:1185 approx, the thing is using the exact same method if I scale to 1:1 equivalent to 1:1000 the drawing IS to scale. Using design jet 500 and Autocad LT 2011.
Any one have any ideas?
Thanks
Hi,
If I do that the drawing in paper space becomes a dot, remember the drawing is set up for metres.
thanks
Go to your layout tab, double click in your viewport and type:
z (enter)
sc (enter)
1000/850xp (where 850 is your scale) (enter)
double click out
Title block about 800x560 units in size, not .8x.56 in layout tab, plot at scale of 1:1 not "FIT" this would cause weird rescale, viewport at scale of 1:850 should work, by the way 850 is not a recognised scale we would use 1:1000. or mark plan as NTS not to scale.
First of all, thanks so much to all of you for your help.
I had read in a tutorial that to scale a dwg which is set up in metres I should multiply the scale x 1000 when in fact I had to divide eg. 1000 div by 1200 = .83, when using
the scale factor .83xp I then get correct scaling. This is a very large site dwg and fits well in A1 at 1:1200.
Thanks again for your help.
A quick tip if you have the viewports toolbar open when you make a viewport if you go into it and zoom E you will see a number appear on the right side where the scales appear as in your case it would be approx 0.83 , this tells me that I should use 1.0 1000/1000 if say I get 4.375 I would type in 5 this is 1000/5 = 1:200 10 = 1:100 hope this makes sense it will zoom automatically to the scale. In metric it is very easy.
Man, you work late (early)!!! 2am!.
That's a great tip, I hadn't noticed that!. It would've saved me a lot of trial and
error zooming to get the right scale, that's a beauty.
Thanks heaps.
