nikki77 Posted September 18, 2012 Posted September 18, 2012 hi, i am not completely new to max and therefore understand the basics; however i have not used it for a long time. i need to create a 3d walkthrough! i have created a model in revit but have been trying to render it and 3 weeks later two thirds of the way through it froze and crashed, so i have been asked to see if i can do it 3d max design 2012 but havent worked in 3d max since 2008! i had a little play around with it to see what i could remember and have been trying to render a basic 3d scene and it just comes out black all the time its really frustrating can anybody help please? Quote
Cad64 Posted September 18, 2012 Posted September 18, 2012 This could be happening for any number of reasons. I need to know more about the scene in order to figure out what's happening though. 1. Do you have a camera set up or are you just rendering the viewport view? 2. Do you have lights set up or are you just using the default lighting? If you had lights in the scene but then deleted them, then you will have no light in your scene at all. You will then have to either manually reset the default lighting or just insert a light. 3. If you're using a daylight system, have you set the proper exposure control in the environment settings? 4. Are you rendering with Mental Ray or the Scanline renderer? Or are you using Vray? 5. Have you applied materials to the objects in your scene? If so, what are they. I would normally ask that you post your file here, but since you're using 2012, I won't be able to open your file here on 2011. If all else fails, and you can't get the render to work, open a new instance of Studio Max and Merge your scene objects into the new file. Or export your scene objects to .obj format and then import them into a new file. Quote
Raudel Solis Posted November 23, 2012 Posted November 23, 2012 wish i had the job of making walkthroughs, or max renders... it's so simple. Quote
