I have searched around for a similar problem, but did not seem to find it. If anyone can point me to where this has been discussed, this thread can be closed.
Anyways, I am about to pull my hair out. I have used a program called Script Maker v. 1.0.4 to create simple batch scripts to update attributes in my title blocks that exist in multiple drawings.
This is the essence of the command:
PSPACE
GATTE
0,0
APPROVALDATE
[here I enter the new text]
Y
_QSAVE
CLOSE
When those commands are generated on with a script containing the desired files, for some reason the script malfunctions around the 7th drawing.
Today, I downloaded a demo of Hurricane for AutoCAD, which is a more user friendly program that does just about the same thing.
This is the script it generates:
(LOAD "C:/PROGRAM FILES (X86)/HURRICANE/LISP/TB_WIZ1.LSP")
TB_WIZ1
"title-sheet"
approvaldate
09/19/12
REGEN
Again, it works first few drawings (in this case the first three drawings), but malfunctions on the fourth drawing.
This is very frustrating because I had no problems with this on my previous computer. Now, on a new faster computer, I having these problems. I am even having them on the exact same drawing files that had no issues on the previous computer.
I have attached the text as it is executed in both versions.
Thanks!
Script1.txt
Script2.txt
Is it your feeling that the script is running too fast? Can a "pause" be built into a script?
I have tried entering a 3 second delay after each set of related commands, it didn't seem to fix the issue. As a matter of fact, it just push off the problem to drawings later on in the sequence. It is so bizarre.
What version of AutoCAD were you running previously?
The previous version was 2013. I am just using it on a new computer. But this script was also successful on 2009 and 2011.
Makes one wonder why then a new computer would have any influence over a script file. Weird.
You got me puzzled.
I am thinking about just trying to reinstall AutoCAD, but that is such a pain.
It might be "crashing" if the drawing does not have the attribute in the drawing. Have you looked to see if the offending drawings do have it?
Yeah, they all have the attribute. I confirmed this by going in manually and performing the commands and it worked fine.
I am trying it now with Autodesk Script pro, and I am having better luck because it uses a timeout feature when a drawing is not responding. From the 16 drawings in this set, #7 through #10 do not update. Oddly enough, script pro shows a status of "failed" for the successful updates, and a status of "done" for the unsuccessful updates. Therefore, I think I have been able to narrow the problem down to this hookup:
Command: _.SCRIPT
Enter script file name : C:\Users\Adam\Desktop\TEST.SCR
Command: PSPACE
Already in paper space.
Command: GATTE
Initializing...
Select block or attribute [block name]: 0,0
Command: 0,0
Unknown command "0,0". Press F1 for help.
I am certain that there is a block located at 0,0. Because when I going in manually and perform GATTE, and enter 0,0, it shows me all the attributes available for modification.
It sounds like you are making some progress at least. I hope it gets better.
After a lot of guess work, it appears the problem was that the script was not finding the coordinates I was providing. I had a few drawings where "0,0" (as "0,0" were the coordinates I was providing to gatte) was obscured by the bottom of the workspace screen. The simple fix was to add a ZOOM and then EXTENTS command before GATTE.
I swear, sometimes AutoCAD presents us with the most trivial and aggravating of issues. Anyways, thanks you guys for your input.
Glad to hear you finally got it figured out and thanks for updating us. :)
I think you answered your own question earlier: after adding a three second delay more files got processed and only later files started to fail.So try 4-5-6-7-8-9-10 second delays until the set is complete.
I have posted elsewhere the problem of zooming sometimes, in some lisps you do the same manually and it works because you have zoomed in, this has been a problem with Autocad for say 20+ years. Its a hidden bug its like if you can not see it I will not work, simple work around is use Z C 0,0 scale this way you control how much you can see, using Z E can bring other problems that wrong objects will be picked.
You should not need any time delays. I have processed multi drawings and never needed time delay.
I would use a bit of lisp to get entries this stops any problems of autocad using and continuing on rather than asking.
PSPACE
(setq ans (getstring "\n[here I enter the new text]'))
GATTE
0,0
APPROVALDATE
ans
Y
_QSAVE
CLOSE
