Cannot move sketch lines
I want to move all the lines of the sketch in order to place it anew relatively to the origin.
I deleted all constraints that might interfere, also dimensions to the origin but no use, it doesn't let me move anything.
And it says: "Check Constraint Settings for Sketch Edit Tools".
What and where are these settings and tools, i didn't find those topics in the Help.
The file is attached.
41-24-15 Drum.ipt
How are you trying to move it? (works fine here - click and drag or add coincident constraint)
I window select all of the sketch, then use the lower end of the long, vertical, construction line as base point and try to put it at the origin, then comes the message
You do not need to select anything. Just click and drag the endpoint to the origin. That is what geometry constraints are all about - they keep your geometry connected.
I forgot to say that i use the move command, then window select and try to move. then comes the message
You do not need to use the Move command.
Click and drag will move the geometry. This is what geometric constraints are all about.
I found a coincident constraint on the origin. the glypth was visible only when i pointed at the origin, although i pressed F8 to show all constraints.
I deleted that constraint also.
I selected the geometry one by one, using the Ctrl button to add, and moved the whole sketch but it twisted, i don't know why.
Indeed i can move everything without the move command, but why doesn't it work, in both cases?
I attach again the modified file
41-24-15 Drum.ipt
Coincident constraints are shown as yellow squares until mouse scrub.
Your sketch twists when you try to drag because you are missing obvious constraints and dimensions.
What does Equal constraint mean for arcs?
In this sketch, to my surprise, i didn't want it so, there are two arcs with the same radius but with different included angles, and with Equal constraints.
Does that constraint mean identical radius only?
And, do i have to constrain, at least one line or arc to the origin?
I made the origin point visible, but i cannot dimension anything to it. do i have to make one member fixed always?
Edited by KarolR
