KarolR Posted September 20, 2012 Share Posted September 20, 2012 I made the first sketch in a new part on the xy plane. I want to make a new sketch, perpendicular to the first, but on a plane that is parallel to the yz plane, and the plane should pass through the end of a line that is in the first sketch. When i define a parallel work plane i can offset it a specific distance. Is there another way to position the plane without entering a specific distance? Maybe to reference the end of the line in the first sketch? The drawing is attached. 41-24-15 Drum.ipt Quote Link to comment Share on other sites More sharing options...
Bishop Posted September 20, 2012 Share Posted September 20, 2012 Click on Work Plane, then click on the point where you want the plane, then click on a line segment that's normal to the direction you want the plane to face. Quote Link to comment Share on other sites More sharing options...
