Hello!
For example I have 5 single hidden objects with the command _HideObjects individually.
Now I need as 3 Objekt.Die remaining 4 hidden objects but will remain hidden.
Is there a way individual choice sets that were hidden with the command _HideObjects unhide without all the hidden objects with the command _UnIsolateObjects unhide.
If such a thing would be really great!
Best regards Martin
  • 2 weeks later...
You can use the following vlisp codes instead:
Functions:
MT:Vanish - to hide objects in selection set:
(defun MT:Vanish (%ss% / n ent)
;; by Mehrdad Ahankhah (Mehre Taban)
(if (and (= 'PICKSET (type %ss%)) (< 0 (setq n (sslength %ss%))))
  (princ (strcat "\nGoing to vanish " (itoa n) " objects."))
  (while (> n 0)
   (setq n (1- n))
   (setq ent (entget (ssname %ss% n)))
   (if (assoc 60 ent)
    (setq ent (subst '(60 . 1) (assoc 60 ent) ent))
    (setq ent (append ent '((60 . 1))))
   (entmod ent)
  (princ "\n'Vanish' done successfully.")
 (T (princ "Nothing to vanish."))
MT:Unvanish - to unhide objects in selection set:
(defun MT:Unvanish (%ss% / n ent)
  (princ (strcat "\nGoing to set visible " (itoa n) " objects."))
  (while (> n 0)
   (setq n (1- n))
   (setq ent (subst '(60 . 0) (assoc 60 ent) ent))
   (entmod ent)
  (princ "\n'Unvanish' done successfully.")
 (progn (alert "Nothing to set visible."))
Commands:
Vanish or Off - to hide all objects
(defun C:Vanish () (MT:Vanish (ssget)))
(defun C:Off () (C:Vanish))
VanishSelected or OffSelected - to hide objects in a selection set and save the selection set with given name
(defun C:VanishSelected (/ name ss)
(setq name (getstring "\nEnter the name of the selection set: "))
(setq ss (ssget))
(set (read (strcat "MehreTaban-" name)) ss)
(MT:Vanish ss)
(defun C:OffSelected () (C:VanishSelected))
Unvanish or On - to unhide all objects
(defun C:Unvanish () (MT:Unvanish (ssget "x" '((60 . 1)))))
(defun C:On () (C:Unvanish))
UnvanishSelected or OnSelected - to unhide objects in a previously saved selection set
(defun C:UnvanishSelected ()
(MT:Unvanish (eval (read (strcat "MehreTaban-" (getstring "\nEnter the name of selection set: ")))))
(defun C:OnSelected () (C:UnvanishSelected))
Shazam for CADTutor.LSP
Thank you for this Lisp. It looks very promising. I will test the same.
Thanks again for the great idea.
Best regards Martin
You are welcome.
