ACAD cannot find arialbd.ttf
Hi,
I am not sure if this really is a lisp or just ACAD related problem. But it crashes my lsp so I will start searching here.
I am using (command.....) to create a text style like this:
(command "_.style" "Logstrup Bold" "arialbd.ttf" 0 1 0 "_N" "_N")
Acad returns this:
Schriftdatei existiert nicht.0
1
0
Unbekannter Befehl "N". Drücken Sie F1-Taste für Hilfe.
Pardon the German, but user is in Austria. It just says that font file does not exist and then "unknown commands" for the remaining parameters.
If I do the same with just arial.ttf then no problem.
The Arial bold font is installed on the PC and the file c:\Windows\Fonts\arialbd.ttf does exist.
Does anybody have any idea why ACAD does not find it?
(the lisp code is running on several machines, and the problem is only on 1)
Best regards
Carsten
May try to hard-code the path:
(if (findfile "C:\\Windows\\Fonts\\arialbd.ttf")
(command "_.style" "Logstrup Bold" "C:\\Windows\\Fonts\\arialbd.ttf" 0 1 0  "_N" "_N")
(prompt "\nUnable to find ArialBD.ttf font on this workstation!")
Thanks Mircea,
The (findfile...) by itself I have already used as part of my trouble-shooting, and it finds the file (because it is there).
I have not tried to code the complete path into the (command "_.style .....) it is worth a try.
Unfortunately I cannot test until after weekend (Austrians leave early on Fridays)
BR
Carsten
That should work well if the path is identical on all workstation.
A possible workaround:
(foreach thePath '("C:\\Windows\\Fonts\\"
                  "C:\\WinNT\\Fonts\\")
(setq thePath (strcat thePath arialbd.ttf))
(if (findfile thePath)
 (command "_.style" "Logstrup Bold" thePath 0 1 0  "_N" "_N")
(if (not (tblsearch "STYLE" "Logstrup Bold"))
(prompt "\nUnable to create \"Logstrup Bold\" text style on this workstation!")
@MSasu,
Here is an alternative method to retrieve the Fonts path:
[color=GREEN];; Special Folder  -  Lee Mac[/color]
[color=GREEN];; Queries the WshSpecialFolders collection for the specified folder[/color]
[color=GREEN];; Ref: http://msdn.microsoft.com/en-us/library/9x9e7edx%28v=vs.85%29.aspx[/color]
([color=BLUE]defun[/color] LM:SpecialFolder ( folder [color=BLUE]/[/color] res spf wsh )
   ([color=BLUE]setq[/color] res
       ([color=BLUE]vl-catch-all-apply[/color]
           ([color=BLUE]function[/color]
               ([color=BLUE]lambda[/color] ( )
                   ([color=BLUE]setq[/color] wsh ([color=BLUE]vlax-get-or-create-object[/color] [color=MAROON]"wscript.shell"[/color])
                         spf ([color=BLUE]vlax-get-property[/color] wsh 'specialfolders)
                   ([color=BLUE]vlax-invoke-method[/color] spf 'item folder)
   ([color=BLUE]if[/color] spf  ([color=BLUE]vlax-release-object[/color]  spf))
   ([color=BLUE]if[/color] wsh  ([color=BLUE]vlax-release-object[/color]  wsh))
   ([color=BLUE]if[/color] ([color=BLUE]not[/color] ([color=BLUE]vl-catch-all-error-p[/color] res))
       res
Example:
_$ (LM:SpecialFolder "Fonts")
"C:\\Windows\\Fonts"
Lee, for sure that is the most effective solution.
  • 2 weeks later...
Thanks for your replies Mircea & Lee,
and apologize for the late response from my side.
I have implemented both parts of the solution in my code:
- Location of fonts folder by Lee
- giving the complete path to the "Command Style...." by Mircea
I am almost sure this solves the problem.
BR
Carsten
