Problem with handles of a 3D spline
I made one turn of a spring, but when i watch from above, the end surface isn't vertical, like the beginning surface.
I tried to add Along Z axis constraint to the end handle, but didn't succeed.
Although the start of the spiral is perpendicular, the handle doesn't have an Along Z constraint, and i cannot apply one to it.
41-24-15 Drum Manufacture.SLDPRT
Is there a reason you are not using Helix for this?
