skenderbender17 Posted September 26, 2012 Posted September 26, 2012 When I go to etransmit drawings I get an error coming up - error opening c:/program files/autodesk/autoCAD 2013/support. I dont know why this is coming up. I have never had an issue with using this command until 2013. any ideas? also, it doesn't let me just drag and drop like in the older versions of CAD. I have to go find the drawings that I'd like and then add them, which is fine for me to do, but i keep getting this error! it also tells me that i have drawings that are added into the folder, which aren't there. so it wont let me add the files I need. help please!!! Thanks, Quote
Dadgad Posted September 27, 2012 Posted September 27, 2012 Have you delved into the MODIFY TRANSMITTAL SETUP options? You may find some relief there. As you seem to use it regularly, I am assuming that you have created a CUSTOMIZED transmittal setup that suits your needs. Quote
skenderbender17 Posted September 28, 2012 Author Posted September 28, 2012 Thanks for the hint, but I have that all set up the way I need it. But it didnt help out with anything. I'm still getting these errors... Quote
RobDraw Posted September 29, 2012 Posted September 29, 2012 When I go to etransmit drawings I get an error coming up - error opening c:/program files/autodesk/autoCAD 2013/support. Is that the correct path to the support folder on your machine? Quote
