CalypsoArt Posted September 28, 2012 Posted September 28, 2012 I'm drawing over a bitmap image where I'm outlining certain objects. I'd like to hatch over them but make the hatch translucent so image underneath will be partially visible. Is this possible in AC 2012? Quote
RobDraw Posted September 28, 2012 Posted September 28, 2012 If you want to print it tanslucent, then you could create a layer for the hatch with a color that can be set to use screening. Quote
RobDraw Posted September 28, 2012 Posted September 28, 2012 2013 does it That is also available in 2011 it's there in 2012. Does that apply to plotting or is just for on screen display? Quote
SLW210 Posted September 28, 2012 Posted September 28, 2012 If you want to print it tanslucent, then you could create a layer for the hatch with a color that can be set to use screening. Just select Plot Transparency in plot settings. Quote
SLW210 Posted September 28, 2012 Posted September 28, 2012 I'm drawing over a bitmap image where I'm outlining certain objects. I'd like to hatch over them but make the hatch translucent so image underneath will be partially visible. Is this possible in AC 2012? I think RobDraw's first suggestion will have to do as the transparency feature wasn't available in 2008. At least I don't believe it was. I believe the question was concerning AC 2012. Quote
RobDraw Posted September 28, 2012 Posted September 28, 2012 Just select Plot Transparency in plot settings. Thanks for that. Quote
ReMark Posted September 28, 2012 Posted September 28, 2012 And the blind shall be made to see again by these ^ ^ ^ good folks! I've deleted my response. Thanks for opening my visual orbs! Quote
SLW210 Posted September 28, 2012 Posted September 28, 2012 I use transparent hatches, really gives some of the drawings a "little something extra". Most here think I use a magic wand on the drawings. Quote
ReMark Posted September 28, 2012 Posted September 28, 2012 You have dispelled the myth and in so doing have crushed my machine-like hydraulic pumping system. :lol: Quote
SLW210 Posted September 28, 2012 Posted September 28, 2012 I'm just an over sized Leprechaun.......all kinds of magic. [ATTACH=CONFIG]37531[/ATTACH] Quote
