Can i extrude perpendicular to a bent surface?
For example i want to extrude a hole from the surface of a cylinder towards the center, but i want that the walls will be in the radial direction.
So far i extruded from a flat plane.
Create tangent workplane or start Hole command and then select hole location.
Attach the file here.
