Overkill command not working...trouble!
Hi Fellow ACaders. I am in big crapola. Using the Overkill command is not deleting objects that are duplicated. It has worked in the past with these same blocks and now...it doesn't recognize that they are duplicated. What gives? Anyone experience this? :(
how about if you set the numeric fuzz up in case objects are not exactly over one another.
yup, already set as 0. any other suggestions?
numeric fuzz? not sure how to do that....help!
When I type pedit, multiple, and select my object, it says no valid objects selected. :(
Can you delete the blocks manually, ie are the layers on and unfrozen?
  • 1 year later...
