How to trim a spline
I projected a spiral onto a plane, and there are many redundant segments.
I drew another line, with coincident constraints to a part of this huge spline and tried to trim the rest of the spline, but it gave me errors.
How can i explode the spline, like in Autocad
Why not create as 2D sketch rather than projecting?
Attach the file here.
what do you mean as 2D sketch? you mean to sketch anew?
I attached a simpler file, with the projected spline
Drum.zip
Right click on the spline and select Split Entity.
Click one or two points to trim at (you might want to create construction geometry first).
Delete the rest of the spline after splitting.
