How to change the selected relation in a sketch
I have a long spline, and i try to make a circle coincident at one point, at the beginning, but when i add a tangent relation it selects an other point.
Add constrained construction line.
Attach your file here.
i made a simpler part file.
I want to make the circle tangent to a specific point, select every one you like.
There is no Nearest constraint, like in Autocad.
And, how do i constrain a spline? i gave two dimensions but it isn't enough.
Should i dimension every vertex of the spline?
For mail.SLDPRT
I do not see construction line as I instructed to create.
There is no obvious location for your desired tangent location.
More information is obviously needed.
I have made another simple drawing. i don't know what construction line to draw, for example:
If i make a tangent constraint between the circle and the leftmost line, the circle snaps with it's closed side to the line.
Let's say i want it to be tangent at the other side of the line, what to do?
For test.SLDPRT
Sounds like you are making this wayyyyyy harder than it should be.
This is a sketching environment - simply drag to close to where you want it and then add constraints.
Nothing in your sketch is dimensioned.
I recommend sketching one line or one circle or arc or something and dimension immediately.
Your design intent in not clear.
