jak ali Posted October 3, 2012 Posted October 3, 2012 I'm new to autocad and came from Metric system country. now I have hard time switching to Imperial system. and I hop you can help me answering some questions please. 1- is there any comparative scale factor between metric and imperial? for instance 1:20, 1:50, 1:250 and so on, compare to what in imperial?. 2 - in the unit dialogue box, if i use metric i only can choose Decimal not any other options like Architectural , engineering..etc. right? 3- if I want to draw in cm or m not millimeter I mean input my distance in cm or m while drawing how to do it? 4- if I want to open a metric drawing in a imperial model space how to switch from M to inch. Thanks Quote
ReMark Posted October 3, 2012 Posted October 3, 2012 (edited) Do yourself a favor and avoid mixing the two systems if you possible can. If you ignore that advice you might want to become familiar with scaling factors like metric to imperial and imperial to metric. And buy yourself a big bottle of Advil or Excedrin too. Edited October 3, 2012 by ReMark Quote
ReMark Posted October 3, 2012 Posted October 3, 2012 (edited) Metric plot scales are as follows (with roughly equivalent Imperial plot scales in parentheses): 1:1 (Full Size) 1:2 (Half Size) 1:5 (3"= 1'-0") 1:10 (1 1/2"=1'-0") 1:20 (3/4"=1'-0") 1:25 (1/2"=1'-0") 1:50 (1/4"=1'-0") 1:100 (1/8"=1'-0") 1:200 (1/16"=1'-0") 1:250 (1"=20'-0") 1:500 (1"=40'-0") 1:1000 (1"=80'-0") Standard metric drawing sheet sizes in millimeters are as follows: A4: 297x210 (11.7"x8.3") A3: 420x297 (16.5"x11.7") A2: 594x420 (23.4"x16.5") A1: 841x594 (33.1"x23.4") A0: 1189x841 (46.8"x33.1") Source: www.academics.triton.edu Edited October 3, 2012 by ReMark Quote
jak ali Posted October 3, 2012 Author Posted October 3, 2012 Thank you so much ReMark for the help. the scale factor you give is what i was looking for..Advil bottle works too LOL Quote
rkent Posted October 3, 2012 Posted October 3, 2012 I'm new to autocad and came from Metric system country. now I have hard time switching to Imperial system. and I hop you can help me answering some questions please.1- is there any comparative scale factor between metric and imperial? for instance 1:20, 1:50, 1:250 and so on, compare to what in imperial?. 2 - in the unit dialogue box, if i use metric i only can choose Decimal not any other options like Architectural , engineering..etc. right? 3- if I want to draw in cm or m not millimeter I mean input my distance in cm or m while drawing how to do it? 4- if I want to open a metric drawing in a imperial model space how to switch from M to inch. Thanks 1) This one was answered already, but remember that the title block will be drawn in mm, so the scale factor only makes sense if the model space objects are drawn as mm, if drawn as cm or m then do the math for the difference. 2) Decimal is your only choice. 3) AutoCAD just sees a unit of 1, so if you decide to draw in cm in a drawing then you stick with that and enter all values as cm. 4) It is best to stay with the original system but if you must convert the drawing one way is -dwgunits (I got that one from reMark recently.) Quote
SLW210 Posted October 3, 2012 Posted October 3, 2012 Get familiar with using -DWGUNITS (include the -). Quote
Boro Nut Posted October 5, 2012 Posted October 5, 2012 Get familiar with using -DWGUNITS (include the -). ^^^ This Basically AutoCAD doesn't know what an inch or a millimeter is. So if you draw something that is 1 unit (inch) in length on your imperial drawing and you then import it to my drawing where and inch is 25.4 units (millimeteres) long, then your inch will be 25.4 times smaller than mine (PWNED). So you will have to scale yours up by a factor of x25.4 or mine down by a factor of or 1/25.4 to make them match. Among other things this is conclusive proof that although millimeteres are 25.4 times smaller than inches, they are actually 25.4 times better. Quote
ReMark Posted October 5, 2012 Posted October 5, 2012 If they are so good why do metric users have so many problems using them? Quote
eldon Posted October 5, 2012 Posted October 5, 2012 If they are so good why do metric users have so many problems using them? It is because AutoCAD was written for the Imperial system, and has its troubles adapting to the Metric system. There do seem to be a fair number of posts about feet, inches, decimal feet, engineers units, architects units, surveyors angles, etc., etc. but you probably gloss over them. Quote
ReMark Posted October 5, 2012 Posted October 5, 2012 I don't think I gloss over them intentionally at least. What strikes me is metric users unable to decide what one unit is going to represent in model space then getting totally perplexed once they get to a paper space layout and viewport looking for an output at a scale that makes sense. Quote
eldon Posted October 5, 2012 Posted October 5, 2012 It might be that all the help is biased to Imperial, and Metric is not covered so thoroughly. Who can tell Quote
ReMark Posted October 5, 2012 Posted October 5, 2012 Biased? Which help are you referring to? CADTutor is UK based. Maybe we should take a poll and see the percentage of users from the only two countries in the world who use imperial units as compared to the remainder of the world that uses metric? LoL Quote
eldon Posted October 5, 2012 Posted October 5, 2012 CADTutor is UK based. And that is why you are seeing so many posts about Metric problems. We don't have ANY Imperial problems. Quote
ReMark Posted October 5, 2012 Posted October 5, 2012 You can now officially give up your day job. Comedy is your forte! Quote
Dadgad Posted October 6, 2012 Posted October 6, 2012 Weaned on 32nds & 64ths, and having spent a good many years doing precision carpentry in the states, thankfully the crew of 30 whom I directed in an for export to the states factory in a metric zipcode was metric based. The work we did by hand would have been really difficult in Imperial units. I doubt there is a craftperson alive, who having worked in both would opt for Imperial. Yeah, the tapemeasures I use these days have Imperial on one edge, and Metric on the other edge, which is the one I use. The need is the same, whether in Imperial or Metric, to ascertain the base unit, check or set it in -DWGUNITS and go back to work with a discernible game plan. Quote
