change incatt.lsp to work with numbers with point, comma etc etc
pmxcad
Hello,
i have a lisp routine incatt.lsp dat increase a attribute. It does only numbers like:
1, 2, 3 etc etc.
Is it possible to change the lisp that it changes/increment(attributes) numbers like: 4.32, 4.33, 4.34 etc So with numbers with a . or , or - and with steps .01?
Thanks
incatt.lsp
Hello,
1, 2, 3 etc etc.
Thanks
Yes, it is possible :)
Can you help me?
Thanks
Pmxcad
Can you help me?
But of course i'll help. listen pmxcad, the way the code is written, the existing value of the attribute doesn't come into play at any way. so whats the deal with "," and "-" ? Will those be the supplied value at prompt? or the resulting incremented value for the attribute entity. if the former, we cant use getreal nor getint for it would not accept those symbols.
if the latter, i suppose we can reverse the sequence by asking to select an attribute first then use the pattern of the existing string to determine the proper prompt (getint/getreal)
Bottom line: How would you prompt for value? or is it numbers after "," and "-" symbols?
Show us an example dude.
Edited by pBe
Just change a couple of lines in code and add increment step this can be just press enter for 1
 (getreal (Strcat  "\nSpecify Starting Number
and
(setq inc (getreal "\nSpecify increment "))
(setq *num* (+ inc *num*))
What i'm after is this Bigal ---- > "," or "-" , when and where does these symbols fit in?
Hello PBE,
the numbers could be: 1.25, 1.26, 1.27 or 1-25, 1-26, 1-27 etc etc
see example.
PmxCAD
test.dwg
Quick mod [untested]
(defun c:incatt ( / tag pre ss1 ) (vl-load-com)
[color="blue"](defun determine (str)
 (list
 (setq pre (vl-string-right-trim "0123456789" str))
 	 (atoi (substr str (1+(strlen pre))))))[/color]
 (setq tag "E_TEXT1")
 (if (setq *num* (cond ( (getint (strcat "\nSpecify Starting Number"  (if *num* (strcat " <" (itoa *num*) "> : ") ": ")))) ( *num* )))
   (while (setq ss1 (ssget "_+.:E:S:L" '((0 . "INSERT") (66 . 1))))
     (if
       (vl-some
         (function
           (lambda ( x )
             (if (eq tag (vla-get-tagstring x))
               (not (vla-put-textstring x [color="blue"](strcat
                          (car (setq p (determine (vla-get-textstring x))))
                               (strcat (if (and (< 0 (cadr p) 9)
                                                (not (eq (car p) "")))
                                             "0" "") (itoa (+ (cadr p) *num*))))))[/color]
         (vlax-invoke (vlax-ename->vla-object (ssname ss1 0)) 'getattributes)
       (princ (strcat tag " Attribute not found."))
HTH
Thanks for the replay, but sorry PBE, its not working correct.
When i give a starting number like 1.25, Autocad returns "Requires an integer value".
And when give a number like "1" it gives all the blocks selected, the number "1" and it doesnt count.
PmxCAD
That is what i wanted to know from the get-go. Tell me. is the existing string on the attribute relevant to the input value?
The modified code increments the "existing value". thats the way i saw it from you attached example.
Are you telling me that there are times that you would input "1-25" or "1,25"?
Are you sure about this? it should work on your "test.dwg"
It's getting pretty late here pmxcad. we'll "increment" tomorrow :)
Edited by pBe
Increase the number of characters in the last.
;; ______________________.`' Customized Programs  '`._____________________;;
;;  Made By ...... TaeEun  12/10/07                                       ;;
;;  Contact me ... [email="arin9916@naver.com"]arin9916@naver.com[/email]                                     ;;
;;             ... [url]http://cafe.naver.com/ptelisp[/url]                          ;;
;;  Client ....... CADTUTOR                                               ;;
(defun c:aa
   ( / f str i f tag num pre post OOv
;        *StartStr121007
;        *IncreaseN121007
       HUE:DivideNum
       HUE:memoVar
       HUE:stringsubst
       HUE:start
       HUE:end
       _divideStr
   ; Sub Function
   (defun HUE:DivideNum ( str / lst s m v1 v2 i j c _NumP _Cal)
       (defun _NumP ( x ) (<= 48 x 57))
       (defun _Cal ( ty v )
           (set v (cons (vl-list->string (reverse (eval ty))) (eval v)))
           (set ty nil)
       (setq lst (vl-string->list str) i -1 j -1)
       (repeat (length lst)
           (setq c (nth (setq i (+ i 1)) lst))
           (cond
               (    (_NumP c)
                   (setq s (cons c s) ) (cond ( m (_Cal 'm 'v1) (setq j (+ 1 j)))))
               (    (and (= c 46) (> i 0) (_NumP (nth (- i 1) lst)) (_NumP (nth (+ i 1) lst)))
                   (setq s (cons c s))
               (t  (setq m (cons c m))
                   (cond ( s (_Cal 's 'v1) (setq v2 (cons (setq j (+ 1 j)) v2))))
       (cond
           ( m (_Cal 'm 'v1))
           ( t (_Cal 's 'v1) (setq v2 (cons (setq j (+ 1 j)) v2)))
       ) (list (reverse v1) (reverse v2))
   ; Sub Function
   (defun HUE:memoVar ( va f m s / v )
       (setq v (if (member (eval va) '(nil "")) s  (eval va)))
       (mapcar 'princ (list "\n" m " <" v "> : "))
       (set va ( f ))
       (if (member(eval va) '(nil "")) (set va v)) (eval va)
   ; Sub Function
   (defun HUE:stringsubst ( new old str / l i ) (setq l (strlen new) i 0)
       (while (setq i (vl-string-search old str i))
           (setq str (vl-string-subst new old str i) i (+ i l))
       ) str
   ; Sub Function
   (defun HUE:start( lst )
       (vla-startundomark (HUE:end nil))
       (list lst (mapcar 'getvar lst))
   ; Sub Function
   (defun HUE:end ( d / doc )
       (setq doc (vla-get-activedocument (vlax-get-acad-object)))
       (and (cadr d) (mapcar 'setvar (car d) (cadr d)))
       (if (= 8 (logand 8 (getvar 'UNDOCTL))) (vla-endundomark doc)) doc
   ; Sub Function
   (defun _divideStr ( str / data i j k pre post )
       (setq data (HUE:DivideNum str)
             k    (last (cadr data))
             j    0
             pre  ""
             post ""
       (foreach s (car data)
           (cond
               (    (< j k) (setq pre (strcat pre  s)))
               (    (> j k) (setq post(strcat post s)))
               (    (= j k) (setq i (atof s)))
           (setq j (+ 1 j))
       (list pre i post)
   ; Error Function
   (defun *error* (s)
       (if OOv (HUE:End OOv)) (princ s)
   ; Main Function
   (setq str  (HUE:MemoVar '*StartStr121007  getstring "StartString  " "A1")
         i    (HUE:MemoVar '*IncreaseN121007 getreal   "Increase Num " 1.)
         OOv  (HUE:Start '(DIMZIN))
   (and
       (vl-string-search "," str)
       (setq str (HUE:StringSubst "." "," str)  f t)
   (mapcar 'set '(pre num post) (_DivideStr str))
   (setq tag  "E_TEXT1"
         num  (- num i)
   (setvar 'ERRNO 0)
   (setvar 'DIMZIN
   (while (= 0 (getvar 'ERRNO))
       (and
           (setq o (ssget "_+.:E:S:L" '((0 . "INSERT") (66 . 1))))
           (vl-some
               '(lambda ( att )
                   (if (= tag (vla-get-tagstring att))
                           (setq num (+ num i)
                                 str (strcat pre (rtos num 2  post)
                           (if f (setq str (HUE:StringSubst "," "." str)))
                           (vla-put-textstring att str)
               ) (vlax-invoke (vlax-ename->vla-object (ssname o 0)) 'getattributes)
   (HUE:End OOv)
)(vl-load-com)
Ok PBE, thanks so far.
your first question: is the existing string on the attribute relevant to the input value? No.
your second question: Are you telling me that there are times that you would input "1-25" or "1,25"? Yes I like to start with give a number like 1.25 and select the first block it gets the value 1.25 and the second one gets the value of 1.26 etc.
Al the block attributes are empty.
PmxCAD
Wow Arnin this works great....super. It is exactly what I meant.
Many Thanks.....
PmxCAD
FWIW:
(defun c:incatt ( / del rtoa p x tag pre ss1 i ) (vl-load-com)
[color="blue"](defun del (str)
 (if (numberp (read str))
 		str (vl-string-translate "-," ".." str)))[/color]
 (setq tag "E_TEXT1" pre "")
 [color="blue"](setq rtoa  (lambda (k)
               (if (zerop (- k (fix k))) (itoa (fix k))
                 (rtos k 2 2)
                 )))[/color]
 [color="blue"](while (not (progn
(if (null pr)(setq pr "1"))
(setq *num* (getstring (strcat "\nEnter Start number <" pr ">: ")))
(if (/= *num* "")(setq pr *num*)(setq *num* pr))
           (if (and (setq p (del *num*)) (numberp (read p)))
              T (prompt "\nInvalid Value")))))
 (setq inc (cond ((getreal
         (strcat "\nEnter Increment Value: "
           (if inc (strcat " <" (rtoa inc) "> ")
                      ": "))))(inc)))
(setq x (vl-some '(lambda (j)
                      (if (vl-string-position (ascii j) *num*) j))
		'("," "-")))[/color]
     (if
       (vl-some
         (function
           (lambda ( x )
               (not (vla-put-textstring x (strcat pre *num*)))
[color="blue"](setq v (+ (read p) inc)
	p (rtoa v)
	*num* (vl-string-translate  "."  (if x x "") p) pr *num*)[/color]
HTH
pBe & Arnin both works ok, but........... when it cums from 1.29 to 1.30 it gives 1.3
instead of 1.30.
PmxCAD
instead of 1.30.
PmxCAD
Dimzin = 0
;;  Ver 1.0 ...... Design & Created                                       ;;
;;      1.1 ...... Add StringCal Function                                 ;;
(defun c:aa
;        *StartStr121007
;        *IncreaseN121007
       HUE:DivideNum
       HUE:memoVar
       HUE:stringsubst
       HUE:StringCal
       HUE:start
       HUE:end
       _divideStr
   ; Sub Function
           (set ty nil)
           (cond
               (    (_NumP c)
                   (setq s (cons c s))
       (cond
           ( m (_Cal 'm 'v1))
   ; Sub Function
       (set va ( f ))
   ; Sub Function
       ) str
   ; Sub Function
   (defun HUE:StringCal ( str f n / _GetPP data1 data2 num i DIMZIN )
       (defun _GetPP ( str / lst l post pre flag )
           (setq lst  (vl-remove  45 (vl-string->list str))
                 post (if (setq l (member 46 lst)) (- (length l) 1) 0)
                 pre  (if (setq l (member 46 (reverse lst))) (- (length l) 1) (length lst))
                 flag (minusp (atof str))
           ) (list pre post flag)
       (setq DIMZIN (getvar 'DIMZIN))
       (setvar 'DIMZIN 0)
       (setq data1 (_GetPP str)
             num   (vl-string->list (rtos (f (atof str) n) 2 (cadr data1)))
             data2 (_GetPP (vl-list->string num))
             num   (vl-remove 45 num)
       (setvar 'DIMZIN DIMZIN)
       (if (< 0 (setq i (- (car  data1) (car  data2))))
           (repeat i (setq num (cons 48 num)))
       (if (< 0 (setq i (- (cadr data1) (cadr data2))))
           (repeat i (setq num (append num '(48))))
       (if (caddr data2) (setq num (cons 45 num)))
   ; Sub Function
   ; Sub Function
   ; Sub Function
             j    0
             pre  ""
             post ""
           (cond
               (    (= j k) (setq i s))
           (setq j (+ 1 j))
       (list pre i post)
   ; Error Function
   (defun *error* (s)
   ; Main Function
   (and
   (setq tag  "E_TEXT1"
         num  (HUE:StringCal num - i)
   (setvar 'ERRNO 0)
   (setvar 'DIMZIN
       (and
           (vl-some
               '(lambda ( att )
                           (setq num (HUE:StringCal num + i)
                                 str (strcat pre num post)
   (HUE:End OOv)
)(vl-load-com)
