create an on error resume (especific)
How to create in Visual Lisp an ON ERROR RESUME NEXT a specific block
in C# i use
try
  COMMAND ERRO
catch
  // GO AHEAD , DONT BREAK
Thanks
Rodrigo
Look into using vl-catch-all-apply
Please remember to use code tags...
[highlight][noparse]
[/noparse][/highlight] Your code here [highlight][noparse]
Sorry, thought it was only for use in large codes, I will do next time.
Do you have a simple example of vl-catch-all-apply ?
The examples I found on google are as difficult to understand much.
Thanks
Rodrigo
Silly example:
(defun c:test ( / num result )
   (if (setq num (getint "\nChoose a number... just not zero: "))
           (if (vl-catch-all-error-p (setq result (vl-catch-all-apply '/ (list 10.0 num))))
               (princ "\nI told you not to choose zero!")
               (princ (strcat "\n10 / " (itoa num) " = " (rtos result 2)))
