Using animated gif line of Polyline
Is there any way to use an animated gif as color of a Polyline?
I have a small gif that changes color, red and green.
Can I import into the Autolisp and use the moving image as
line color of Polyline?
Up to my knowledge, it is not possible to associate an image to a polyline as "color". What you can do is use an image as hatch pattern if you have Express extension installed - please check the SUPERHATCH command.
But please keep in mind that animated GIF isn't supported by AutoCAD - if you try to attach/insert/use as hatch pattern such file to your drawing only the first frame will be shown.
It depends what you want in fact to achieve, but an AutoLISP routine or a script that control display may do the trick - please check this previous discussion.
I already noticed the solution provided by Lee Mac; in fact is quite similar with one approach from the thread I have suggested to you.
Regarding the usage of images in drawings, there are two methods: embed and link; both works very well with many image formats, although animated formats aren't supported up to this time.
