Looking for similar dynamic blocks features in Inventor
Hi All,
Please don't give me a hard time by saying that was AutoCAD and this is Inventor ;)
I am about making a wooden structure out of 90x45 stud. After extruded the stud 90x45x250mm and save it as stud.ipt I went through adoptive features in Inventor but you can not insert stud.ipt several times in assembly and having the adoptive feature at the same time.
I want some flexibility to build my structure using just one part stud.ipt.
Is it possible?
I hope I made my point clear. Please let me know if you need more information on this.
Cheers
Ali
iPart
iLogic
Frame Generator
(any one of those 3 options) I would use Frame Generator with custom profile.
Thanks,
I went for frame generation but all of them related to Metalic sections. There is a drop-down menu for material but is there any solid rectangular section? I briefly looked at it but didn't find any.
test.zipI cannot select my sketch to make a frame out of frame generator?!
I haven't had time to look at your file, so I may be way off target here, but you can't use sketches in the assembly as a skeleton for frame generator. The sketch has to be in a part file. Whenever I use Frame Generator, I will 99% of the time create a part named "FRAMEGEN SKELETON" or something similar, and it only contains a sketch.
Awesome:shock:
I like this ... ;)
