Ilogic Extrude up to a surface
Hi Everyone,
I’m a design engineer for a company that make press tooling to manufacture parts. I am trying to automate the design process using Ilogic. I know the basics but the part I’m having trouble with is importing a surface.
Our process is to 3D scan the part which then gets a surface from this and extrude up to the actual surface.
Is there any way in ilogic to automate this process. Ideally I would like it to come up with a browse button you select the surface file .stp or .iges. Once the surface is in the part file it extrudes up to the surface from a plane.
Any Ideas Anyone
Cheers
Chris
