Well, you see, problem is, I don't know the exact shape of cross sections yet. I started with a extruded triangle, and here's where I got after adding more vertexes, lines and faces. I don't know how the final shape will look like, I need to experiment, add, remove, join, divide these vertexes, lines and faces to see what will finally work.
I understand that you are trying to work it all out.
It is important to maintain symmetry though as you move along.
I would keep copies of your sections available, and turn on your solid history,
so that if you get lead astray during the design process, you can get back to an earlier configuration.
  • Replies 24
  • laukejas
    10
  • tzframpton
    6
  • JD Mather
    5
  • SEANT
    2
Well... That's not easy. What about Inventor Fusion? Would it allow to edit solids in the way I want?
A few of us have already told you this earlier in this thread. :)
Yeah, you could give that a shot. Whole new ballgame though. You work with reference planes and profiles, so much different than AutoCAD.
Sorry, but I still don't get how exactly to do that. I mean not editing cross-sections and then lofting everything (I tried that, but it's guessing game), but make a solid, and then gradually add complexity. Like you would draw some 3d shape from background blueprint.
I would use Autodesk Inventor for this design (not free).
Inventor Fusion is free (you know what they say about free stuff - you get what you paid for..............)
and add on an equal cost for training
and add on about 3 years of experience - including at least 6 months in surface modeling.
