Lannabulls Posted October 15, 2012 Posted October 15, 2012 3D Studio max 2013 First of sorry about my beginner question, just start with 3d Max 2013 since a few days, basically no expereince. Reading in internet i noticed that max 2013 has many updates, service packs, product updates and so on, for a new user as i'm that bring me in total confusion, can you explain please what exactly i must install or show me some tutorial that can help to make myself understand? Thank a lot sorry again for my beginner question and my poor writen english, thank!!!!!! Quote
Cad64 Posted October 15, 2012 Posted October 15, 2012 Updates and service packs fix problems with the program. You should always install them when they become available. http://usa.autodesk.com/adsk/servlet/ps/dl/index?id=2334435&linkID=9241178&siteID=123112 Quote
Lannabulls Posted October 15, 2012 Author Posted October 15, 2012 Thank a lot! As soon as installed max 2013 i went check for updates cause i know that install update is important, i found the page that you kindly link however my question, sorry about no expereence, is waht i must install? There are so many updates? Can you explain to me please? my os is windows 7 64 bit Hotfix - Issue reading CATIA V5 R21 SP2 and SP3 CATPart files Autodesk Composite 2013 Service Pack 2 Autodesk 3ds Max 2013 Product Update 5 Autodesk 3ds Max 2013 Product Update 4 Autodesk 3ds Max 2013 Product Update 3 Backburner 2013.0.2 Windows version for 3ds Max/3ds Max Design 2013 Autodesk Composite 2013 Service Pack 1 Autodesk 3ds Max 2013 Product Update 2 Autodesk 3ds Max 2013 Product Update 1 Autodesk IPv4 Network License Manager for Windows Autodesk IPv6 Network License Manager for Windows As example "Autodesk 3ds Max 2013 Product Update", there are 5: 1,2,3,4,5! I must install all or i just install the 5th one? "Autodesk Composite 2013 Service Pack": 2 service packs, i must installl both on just service pack 2? What is "Hotfix - Issue reading CATIA V5 R21 SP2 and SP3 CATPart files" this one i understand what is about, must install it "Autodesk IPv4 Network License Manager for Windows" What is this about? Can you explain to me what is this for, may i know but i'm not sure "Autodesk IPv6 Network License Manager for Windows" this update i donty need it cause i dont use IPv6 internet connection Sorry again for my very beginner questions, just install max 2013 since a few days, my first time ever, thank alot!!!!! Quote
Cad64 Posted October 15, 2012 Posted October 15, 2012 I would recommend that you install all 5 product updates. I believe they are all different and unique. You only need to install Service Pack 2. It contains both Service Pack 1 & 2, so you don't need to install Service Pack 1. I doubt you will need to install the Network License Manager or the Backburner update or the Catia update. You can install them if you want, but probably not necessary. If you want information about each update, view the ReadMe file that accompanies each download. Quote
Lannabulls Posted October 15, 2012 Author Posted October 15, 2012 Thank a lot! about Autodesk 3ds Max 2013 Product Update 1-5 i ask if i must install all or just the 5th one cause i went read "readme" pdf of update 5 it says: "http://www.autodesk.com/3dsmax-updates. It is recommended to uninstall any versions of Product Update 1 prior to installing Product Update 5." "Note: Product Update 5 includes all previous Product Updates for 3ds Max 2013 / 3ds Max Design 2013." Therefore as obviously you can understand by my poor written english, i'm italian, i repeat the question: i just install update 5 or i must install all from 1 to 5? If i understood well just the 5th one is enogh! About Backburner, in a domestic situaton as mine, 2 pcs connected, 2 fast machines with good hardware for 3d, it make sense install Backburner or not at all? Thank a lot! Quote
Cad64 Posted October 15, 2012 Posted October 15, 2012 I can't tell you what YOU need to install. YOU are the only one who knows what YOU need to install. In regards to Backburner, I thought you were a beginner so I didn't think you would be using it. If you have 2 pc's connected then yes, install Backburner. I don't know what type of files you're working with, but if you're working with Catia files, then install the Catia update. If you need the Network License Manager installed then install that too. Like I said before, you need to view the ReadMe file that accompanies each download and decide for yourself if you need to install it or not. Then follow the instructions and install accordingly. If the ReadMe says you only need to install the last update in the series, then just install the last update. If you need further information about the updates, you should probably contact Autodesk with your questions. Quote
