ksc Posted October 16, 2012 Posted October 16, 2012 Hi everyone, can someone please guide me through to making a 11x8.5 title block template. I have made a few in model and paper space but when i insert them in layout they appear very small. What am i doing wrong, please can someone go through this process with me, i am using autocad 2008, you can contact me through my email if it helps , solihull9@hotmail.com Many thanks Quote
Bogbadbob658 Posted October 17, 2012 Posted October 17, 2012 Can you post a dwg of what you have done so far? It will speed up the process. Quote
Murph_map Posted October 17, 2012 Posted October 17, 2012 When you go to a layout make sure you set the page size to fit the 11x8.5. Use PAGESETUP command and click on modify to set up the page/layout. Quote
BIGAL Posted October 18, 2012 Posted October 18, 2012 Start by drawing a rectangle 10x7.5 the 1/2" is the non plottable part of a sheet of paper draw everything inside this rectang regarding Title details and all should work. Create a Mview within the available area then do Z E should see you model now on a 11x8.5 Quote
ksc Posted November 8, 2012 Author Posted November 8, 2012 Hi Guys sorry for getting back to you so late have been unwell, but would like to thank you all who replied with their tips. Everything is working fine thanks again Quote
