stevsmith Posted October 17, 2012 Posted October 17, 2012 (The description has been stolen because it describes exactly what im looking for ) I have a macro that I use to generate a pdf of an open drawing. My drawing filename is simply the part number. I want to Macro to append a revision to the end of the filename before saving as a pdf. I carry the current rev in a custom propety in the model. I have a note on my sheet format that references this to diplay the rev in the title block. I can't seem to use part.getcustominfo2 because it looks in the custom property area of the drawing (which is empty) instead of referencing from the model I do not know how to access the properties of the referenced model like my notes do ($PRPSHEET:REV). Any ideas how to do this? Sub pdfmaker1() Dim swApp As Object Dim Part As Object Set swApp = Application.SldWorks Set Part = swApp.ActiveDoc Dim swModel As SldWorks.ModelDoc2 Dim WholeFilename As String Dim Prefix As String Dim MyFilename As String Dim MyPath As String Dim CurrentRev As String Dim LastParenPosition As Integer Dim PDFName As String Set swModel = swApp.ActiveDoc WholeFilename = swModel.GetPathName CurrentRev = swModel.GetCustomInfoValue("", "Revision") If CurrentRev = "--" Then CurrentRev = "-Rev0" Else CurrentRev = "-Rev" & CurrentRev LastParenPosition = InStrRev(Prefix, "\") MyFilename = Right(WholeFilename, Len(WholeFilename) - LastParenPosition) If Len(MyFilename) = 0 Then MsgBox ("Drawing not saved yet") If Len(MyFilename) = 0 Then End MyFilename = Left(MyFilename, Len(MyFilename) - 7) + CurrentRev + ".pdf" Set Part = swApp.ActiveDoc Part.EditSketch swApp.ActiveDoc.ActiveView.FrameState = 1 Part.SaveAs2 MyFilename, 0, True, False Part.EditSketch MsgBox MyFilename + " saved as a pdf" End Sub My collegue found this link which asks the same question but our knowlege of VB is non existent. http://compgroups.net/comp.cad.solidworks/api-get-custom-prop-from-referenced-model/15615 Any help would be much appreciated. Quote
stevsmith Posted October 17, 2012 Author Posted October 17, 2012 It's ok folks I managed to get a code for it. Dim swApp As SldWorks.SldWorks Dim swModel As SldWorks.ModelDoc2 Dim swDraw As SldWorks.DrawingDoc Dim swCustProp As CustomPropertyManager Dim valOut As String Dim valOut1 As String Dim valOut2 As String Dim resolvedValOut As String Dim resolvedValOut1 As String Dim resolvedValOut2 As String Dim Filepath As String Dim FileName As String Dim ConfigName As String Sub main() Set swApp = Application.SldWorks Set swDraw = swApp.ActiveDoc ' Check to see if a drawing is loaded. If (swDraw Is Nothing) Or (swDraw.GetType <> swDocDRAWING) Then ' If no model currently loaded, then exit Exit Sub End If Set swView = swDraw.GetFirstView Set swView = swView.GetNextView Set swModel = swView.ReferencedDocument ConfigName = swView.ReferencedConfiguration Set swCustProp = swModel.Extension.CustomPropertyManager(ConfigName) swCustProp.Get2 "NewPartNo", valOut, resolvedValOut 'Change the custom property name here swCustProp.Get2 "AssyDescription", valOut1, resolvedValOut1 'Change the custom property name here swCustProp.Get2 "CurrentRev", valOut2, resolvedValOut2 'Change the custom property name here Filepath = "C:\Drawings\" FileName = Left(swDraw.GetTitle, Len(swDraw.GetTitle) - 9) swDraw.SaveAs (Filepath + resolvedValOut + " - " + resolvedValOut1 + " - Rev" + resolvedValOut2 + ".PDF") 'Change the custom property text here MsgBox resolvedValOut + " - " + resolvedValOut1 + " - Rev" + resolvedValOut2 + " Saved as a PDF" End Sub Quote
