dsibbo Posted October 17, 2012 Posted October 17, 2012 Can anyone help me with the attached block. I want to rotate my block so that the attribute rotates with it but stays the correct way around so it is still readable and no upside down text. So far I can only rotate the block but the attribute won't rotate with it at all. Is there a step I have missed out? Thanks (I've posted this in the AutoCAD general section too but expected it to be moved here) Dy Block Help.dwg Quote
Mike_Taylor Posted October 18, 2012 Posted October 18, 2012 Make sure your attribute is locked in the attribute properties. Place a move parameter on the attribute base point and set the number of grips/points to zero. Use a rotate parameter/action on your block and the move parameter you just put in (not the actual text). Select the move and rotate and make sure the chain actions option is selected as yes. See attached for more info. Sample Rotation.dwg Quote
tzframpton Posted October 18, 2012 Posted October 18, 2012 I agree with Mike.... Move Parameter/Action plus the Chain Action is the best. Quote
srini Posted July 20, 2016 Posted July 20, 2016 i want to rotate text with rest of block, but only not end up "up side down". i want text to rotate 180 degrees, when i rotate block more than 90 degrees. how can i do that ? Quote
iconeo Posted July 25, 2016 Posted July 25, 2016 i want to rotate text with rest of block, but only not end up "up side down".i want text to rotate 180 degrees, when i rotate block more than 90 degrees. how can i do that ? Like so? http://www.iconeo.net/2016/rotating-dynamic-block/ Quote
srini Posted August 3, 2016 Posted August 3, 2016 Like so? http://www.iconeo.net/2016/rotating-dynamic-block/ Got it thanks. Quote
BIGAL Posted August 4, 2016 Posted August 4, 2016 Hi guys I was hoping you can help with my prior post http://www.cadtutor.net/forum/showthread.php?97667-Auto-rotaing-text-to-any-UCS Its a very similar problem I just dont do enough with dynamic blocks to know where to find the right option to attach to my attribute, Mike_taylor your sample.dwg is almost what I want the same type of idea but must be linked to the current UCS/view. Quote
