StuboJones Posted November 7, 2008 Posted November 7, 2008 Evening Gents, After searching through allot of threads as far back as 2006, I’m struggling a tad. Add to that that I’ve never produced a lisp in my life, you can understand I’m somewhat oblivious to what I'm about to ask, or whether I should be paying for it (had a similar experience in Amsterdam ) I found and used the PMSFptwtx lisp to great effect, but stumbled when I tried to use it on a recent drawing from our architect. The levels that I wished to utilise were all embedded in a block as a variable value, which I’m assuming he/she would change with the attribute editor. Exploding the block would simply display the text 'LEVEL', which was of no use with the PMSFptwtx lisp. Is it possible to extract the variable value, and then create a 3D point from this at the blocks insertion point? Much appreciate your help Stu Quote
StuboJones Posted November 7, 2008 Author Posted November 7, 2008 Cant tell this is my first time can you? Running ACAD2009. Quote
wizman Posted November 7, 2008 Posted November 7, 2008 here's a modified version for blocks...'-) ;;;OriginalAuthor: Pedro Miguel da Silva Ferreira Email:pedro_ferreira@netcabo.pt ;;;Web page: http:pwp.netcabo.pt/pedro_ferreira ;;;Location: Portugal, Lisboa ;;;Modified by Wizman 06NOV08 ;;;***This version works for Blocks having attribute*** (defun c:PMSFptwtxt (/ *modelspace* aup_ini cmd_ini counter diz_ini edg_ini fla_ini letxt lun_ini ort_ini osm_ini plt_ini txt txtent txtx txty txtz uni_ini xyz ) (vl-load-com) (defun W1 (w1_ent / blk_tag enam eobj) (vl-load-com) (setq enam w1_ent) (setq eobj (vlax-ename->vla-object enam)) (setq blk_tag w1_tagname) (setq txtz nil) (if (= (vla-get-hasattributes eobj) :vlax-true) (progn (foreach n (vlax-safearray->list (variant-value (vla-getattributes eobj) ) ;_ end_variant-value ) ;_ end_vlax-safearray->list (if (= (strcase (vla-get-tagstring n)) (strcase blk_tag) ) ;_ end_= (if (numberp (read (vla-get-TextString n))) (setq txtz (atof (vla-get-TextString n))) ) ;_ end_if ) ;_ end_if ) ;_ end_foreach ) ;_ end_progn ) ;_ end_if ) ;_ end_defun ;;; ;;;-------------------;;; (defun inivar () (setq cmd_ini (getvar "cmdecho") fla_ini (getvar "flatland") osm_ini (getvar "osmode") ort_ini (getvar "orthomode") plt_ini (getvar "plinetype") aup_ini (getvar "auprec") uni_ini (getvar "unitmode") lun_ini (getvar "lunits") diz_ini (getvar "dimzin") edg_ini (getvar "edgemode") ) ;_ end_setq (setvar "CMDECHO" 0) (setvar "FLATLAND" 0) (setvar "OSMODE" 0) (setvar "ORTHOMODE" 0) (setvar "PLINETYPE" 2) (setvar "AUPREC" 0) (setvar "UNITMODE" 1) (setvar "LUNITS" 2) (setvar "DIMZIN" 0) (setvar "EDGEMODE" 1) ) ;_ end_defun ;;; ;;;Convert a list of reals into strings (defun linhaxy (px) (vl-princ-to-string px) ) ;_ end_defun (inivar) ;;;-------------------;;; (defun recvar () (setvar "CMDECHO" cmd_ini) (setvar "FLATLAND" fla_ini) (setvar "OSMODE" osm_ini) (setvar "ORTHOMODE" ort_ini) (setvar "PLINETYPE" plt_ini) (setvar "AUPREC" aup_ini) (setvar "UNITMODE" uni_ini) (setvar "LUNITS" lun_ini) (setvar "DIMZIN" diz_ini) (setvar "EDGEMODE" edg_ini) ) ;_ end_defun (command "layer" "make" "PMSFptwtxt-3dpoints" "COLOR" "1" "" "" ) ;_ end_command (setq w1_tagname (getstring "\n>>>...Enter Tag name of attribute...>>>: " ) ;_ end_getstring ) ;_ end_setq (setq *modelspace* (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object)) ) ;_ end_vla-get-modelspace ) ;_ end_setq (setq txt (ssget '((0 . "INSERT")))) (setq letxt (sslength txt)) (setq counter 0) (while (< counter letxt) (progn (w1 (ssname txt counter)) (setq txtent (entget (ssname txt counter))) (setq txtx (car (cdr (assoc 10 txtent)))) (setq txty (cadr (cdr (assoc 10 txtent)))) (setq xyz (list txtx txty txtz)) (command "layer" "set" "PMSFptwtxt-3dpoints" "") (command "point" xyz) ) ;_ end_progn (setq counter (1+ counter)) ) ;_ end_while ;;; (recvar) ;;; (command "layer" "set" "0" "") (princ) ) ;_ end_defun (alert "Type PMSFptwtxt and press enter to run\n\n *Author: Pedro Ferreira*" ) ;_ end_alert Quote
StuboJones Posted November 10, 2008 Author Posted November 10, 2008 Awesome! You have no idea how good you're gonna make me look Thanks Wizman. Quote
