suryatry26 Posted October 18, 2012 Posted October 18, 2012 For File Copying One File To Other File Why its asking File Or Directory each time? How to Give File is Default xcopy /s C:\Test\TestCopy\1\Test.DGN C:\Test\TestCopy\2\Test.DGN As per this in my bat having 100 file means here i want to give "F" for each file copying...Hw to make default "F" Quote
ReMark Posted October 18, 2012 Posted October 18, 2012 (edited) You're using XCOPY? Jeez, I haven't seen anyone use that in quite a while. Did you consider the use of wildcards? For example, I want to copy all drawing files that start with letter "M" I would write M*.dwg as there is no need to specify anything more than that. To copy all drawings no matter what they are named I would use *.dwg as my criteria. Click on the link below. Look at some of the examples included. You'll have to scroll down a bit. http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/xcopy.mspx?mfr=true You might want to include the /v switch. /v: Verifies each file as it is written to the destination file to make sure that the destination files are identical to the source files. Edited October 18, 2012 by ReMark Quote
