ittayd Posted October 20, 2012 Posted October 20, 2012 I want to draw a wall with irregular bricks. Meaning these are old elonite bricks that are not exactly rectangular and are not all of the same length. Thank you, Ittay Here's an example of what I want to achieve: Quote
MSasu Posted October 20, 2012 Posted October 20, 2012 Unfortunately you didn't stated the software you are currently using. If is about AutoCAD full and also have the Express extension installed then can use the SUPERHATCH command which will allow you to define a pattern from posted sketch. Quote
ittayd Posted October 21, 2012 Author Posted October 21, 2012 Thanks! superhatch looks like what I need. Quote
provas_ce Posted October 21, 2012 Posted October 21, 2012 Owow I also looking for this solution.. Thanks ittayd for posting and thanks MSasu for solution. Quote
