Liesl_Mitchell Posted October 23, 2012 Posted October 23, 2012 Hello, I am using AutoCAD CIvil 3D 2011. Just recently, I am unable to insert images. Whether I use the insert command from the menu or type in the command, the program freezes at that point until I hit escape. Very frustrating since now I can't work! Image manager works and insert block works. Is there a different command I can try for inserting a raster image? I haven't made any changes to my computer, no upgrades since the last time the command worked (that I can remember) - I tried a system restore but that didn't work. Please help! Thanks! Quote
MSasu Posted October 24, 2012 Posted October 24, 2012 Have you checked the message in command prompt? It may be just the fact that the FILEDIA system variable is set to 0 which prevents the file selection dialog to pop-up and path is expected on prompter; hence the revert after . Please set the said variable to 1 and try again. Quote
