Define a regen after closing DWGPROPS?
Hi folks,
I have very limited lisp understanding and generally try to work with what i have already been shown. I want to set up a ribbon tool for users to enter drawing details in the document properties which will auto fill the custom fields I have set up in our template file layout tabs. Currently when the edit is comlete and the dialogue is closed the fields remain unchanged until a regen is performed. Below is my poor attempt at redefining the dwgprops command but it clearly doesn't work.
; Define Document properties to regen on close
(command ".undefine" "dwgprops")
(defun c:dwgprops ()
(setvar "cmdecho" 0)
(command "-dwgprops")
(command ".regen")
(command ".dwgprops)
(setvar "cmdecho" 1)
If it is possible I'd welcome some pointers - thanks.
  • Replies 25
  • Keywordkid
    10
  • dober
    3
  • BlackBox
    3
  • nod684
    2
Posted Images
Couple of things....
First, you seem to be missing a close quote here:
(command ".regen")
(command ".dwgprops[color=red][b]"[/b][/color])
Your logic is sound, in that you're wanting the changes made to DwgProps to be reflected when you're done making changes. Where you've overlooked one option for accomplishing this is by not having a bit more experience - Don't worry, you'll get there. :thumbsup:
When you consider that you're wanting to consistently perform a supplementary action following a specific Command, Undefining, and Redefining is one way to go about it. Were I to do this (and I may now add this to my setup, so for that I thank you for asking the question), I would employ a simple Command Reactor.
By using a Visual LISP Command Reactor, we can preclude the need to undefine a Command (in this case DwgProps), and instead simply monitor for the CommandEnded event (in lieu of CommandWillStart, CommandCancelled, etc.), as only when the DwgProps Command has successfully ended do we want our supplementary action to take place (in this case a regen).
Another advantage of using Visual LISP in this case is that we can regen the viewports without using another Command, as this has been exposed to the ActiveX API.
What does all of this look like?
Simple; to test load this psuedo-code:
(vl-load-com)
(defun DwgPropsCommandReactor:Start ()
 (or *DwgPropsCommandReactor*
     (setq *DwgPropsCommandReactor*
            (vlr-command-reactor
              "DwgPropsCommandReactor"
                (:vlr-commandended . DwgPropsCallback:CommandEnded)
 (prompt "\n  >>  DwgProps command reactor loaded ")
(defun DwgPropsCallback:CommandEnded (rea cmd)
 (if (wcmatch (strcase (car cmd)) "DWGPROPS")
   (vla-regen (vla-get-activedocument (vlax-get-acad-object))
              acAllViewports
(defun c:StopR ()
 (if *DwgPropsCommandReactor*
     (vlr-remove *DwgPropsCommandReactor*)
     (setq *DwgPropsCommandReactor* nil)
     (prompt "\n** DwgProps command reactor stopped ** ")
(DwgPropsCommandReactor:Start)
** Note - Be sure to NOT have the DwgProps Command undefined.
** Edit to add - I've also included a "STOPR" command so that if you'd like to turn this reactor of, you may.
HTH
Edited by BlackBox
Many Thanks RenderMan,
Glad my idea may prove useful I'll give your code a try and see if I don't make a mess of it :D
Thanks RenderMan - This works a treat! I just need to update the company Ribbon tools to include DWGPROPS to make it simple to run.:D
HI RM,
Related to my initial idea, do you know if there is a method for pre-selecting the 'custom' tab in the DWGPROPS dialogue? - I want to make it as easy as possible to edit the fields for the users without running through instructions and tutorials.
Thanks,
KWK
Sorry for the delayed response - You're welcome, I'm happy to help. :beer:
Unfortunately not that I am aware of; once within a Command's dialog, AutoLISP, and even Visual LISP for that matter, are of little use.
I thought that might be the case when Googling gave me no useful results, I've resorted to some text instructions in Defpoints just off the side of the Layout and hope the users will actually read it!!
Thanks for your help. :thumbsup:
Guest kruuger
HI RM,
Thanks,
KWK
yes, with own custom prop dcl window ;)
pros:
- multiple delete
- reorder, up-down
cons:
- not re-sizable
kruuger
Cup.dcl
EditCustomProperties.lsp
This looks interesting, is it just the dcl file that I need to edit for my preferred fields?
Guest kruuger
what do mean by fields ?
you can change width of DCL to make it wider.
more props looks like this:
kruuger
Hi kruuger,
I think we may be at cross purposes.
I have set up new fields in the drawing properties, which are applied to the title block details for each layout tab on our template(s). The fields are defined in the custom tab of DWGPROPS and prefilled with (suggestions/examples), I was hoping that I could direct users to the custom tab to edit the fields according to their project parameters. I have just tried your files and see how they come up which would be great if the same editing features were available as in DWGPROPS.
Please correct me if I'm mistaken.
Thanks,
KWK
(By the way this code is very useful for re-ordering the values logically without starting over - just organised my properties more logically - thanks)
Guest kruuger
Hi kruuger,
Thanks,
KWK
why users can't use my program instead of dwgprops ? it is the same properties.
kruuger
Thank kruuger
Something I've been looking long :):)
Danke kruuger
Sowas suche ich schon lange
Guest kruuger
thanks dober, nod684
how usefull will be import/export to file guys ?
maybe resizable window (3 states) ?
kruuger
Hi Kruuger,
I looked at your program again and realised my mistake, I didn't double click each property :oops: I was single clicking expecting it to hilight the selected property as the DWGPROPS dialogue does but I now realise you have a separate pop up.
Thanks,
KWK
kruuger
Krugger, the only difference is that when i use Expresstool's Propulate command, it can update multiple drawings' custom properties.
your routine is good for one drawing (or am i mistaken) but is still as good.
haven't tried the import/export yet though
Guest kruuger
we can add also dwgprops to folder with files via ObjectDBX
(defun c:PRO (/ _AddCustom)
 (defun _AddCustom ( doc )
   (vla-AddCustomInfo (vla-get-SummaryInfo doc) "One" "1")
 (LM:ODBX '_AddCustom nil T)
need Lee wraper: http://lee-mac.com/odbxbase.html
kruuger
For clarity to my users I have edited the label to include some instruction so they don't make my mistake:
I just edited the CUP.dcl
//            MAIN_DIALOG            //
CUP : dialog {
 label = "Custom properties";
 width = 62;
 height = 5;
 : row {
   : list_box {
     key = "PROP";
     label = "Name (Double click each property to edit)";
     width = 35;
     multiple_select = true;
     fixed_width_font = true;
   BUTTON_EDIT;
 BUTTON_OK_CANCEL;
Thanks Kruuger :)
Guest kruuger
good point Keywordkid.
to get more space you can delete fixed_width_fint line (standard font)
kruuger
