KarolR Posted October 26, 2012 Posted October 26, 2012 I use the text command in a sketch, but it comes out vertical and i want to rotate it. In the Text dialog box there is a Rotation box, but it isn't activated. I cannot impose vertical or horizontal constraints either. WP_Cylinder.ipt Quote
KarolR Posted October 26, 2012 Author Posted October 26, 2012 I succeeded in rotating, i placed a parallel constraint to the bounding rectangle Quote
drwhite Posted March 2, 2015 Posted March 2, 2015 I succeeded in rotating, i placed a parallel constraint to the bounding rectangle I did that "once", now I cannot rotate it 90 more degrees. The text come in inverted. What now? Quote
drwhite Posted March 2, 2015 Posted March 2, 2015 I succeeded in rotating, i placed a parallel constraint to the bounding rectangle When I try to rotate the second time with a different parallel constraint, it says it will be over-constrained. Quote
JD Mather Posted March 2, 2015 Posted March 2, 2015 Delete the constraint. Add one dimension to the textbox. Now you can drag lower left corner of box to any desired angle. Add angle dimension. Tip #38 http://home.pct.edu/~jmather/skillsusa%20university.pdf Quote
drwhite Posted June 11, 2015 Posted June 11, 2015 JD, The dimension thing works. But why is my text backwards???? Did I reset something on the text menu? Quote
