Lannabulls Posted October 28, 2012 Posted October 28, 2012 3DS Max 2013, inside my Max installation i find a folder named "external plugins", inside i find plugin for After Effects, share files with ".sof" extension between the 2 applications . These plugsin refer to After Effects 4 and 5, what about After effects 5.5 and 6? The above mentioned plug in After Effects 5 it works at list with 5.5 edition too? Thanks a lot! Quote
Cad64 Posted October 29, 2012 Posted October 29, 2012 Sorry but I don't use Max 2013, so I don't have those plug-ins. I also don't use After Effects, so I don't know if those older plug-ins are compatible with newer versions. I would assume that they will not work with newer versions, but that's just a guess. Quote
