Cazza Posted October 29, 2012 Posted October 29, 2012 Could someone please help me modify this LISP code as I am a begginer when it comes to LISP. I found the below LISP on one of the forums on this site and it is great, only problem is that I can only select one attribute at a time. Is there any way to change this to select a window rather than individually? (defun mydcl (zagl info-list / fl ret dcl_id) (vl-load-com) (if (null zagl) (setq zagl "Select") ) ;_ end of if (setq fl (vl-filename-mktemp "mip" nil ".dcl")) (setq ret (open fl "w")) (mapcar '(lambda (x) (write-line x ret)) (list "mip_msg : dialog { " (strcat "label=\"" zagl "\";") " :list_box {" "alignment=top ;" "width=51 ;" (if (> (length info-list) 26) "height= 26 ;" (strcat "height= " (itoa (+ 3 (length info-list))) ";") ) ;_ end of if "is_tab_stop = false ;" "key = \"info\";}" "ok_cancel;}" ) ;_ end of list ) ;_ end of mapcar (setq ret (close ret)) (if (setq dcl_id (load_dialog fl)) (if (new_dialog "mip_msg" dcl_id) (progn (start_list "info") (mapcar 'add_list info-list) (end_list) (set_tile "info" "0") (setq ret (car info-list)) (action_tile "info" "(setq ret (nth (atoi $value) info-list))") (action_tile "cancel" "(progn(setq ret nil)(done_dialog 0))") (action_tile "accept" "(done_dialog 1)") (start_dialog) ) ;_ end of progn ) ;_ end of if ) ;_ end of if (unload_dialog dcl_id) (vl-file-delete fl) ret ) ;;;=============================================== ================================= ;;;Written By Michael Puckett. ;;;(setq all_layers (tablelist "LAYER")) (defun tablelist (s / d r) (while (setq d (tblnext s (null d))) (setq r (cons (cdr (assoc 2 d)) r)) ) ) (defun C:CHATTLAY ( / *error* lay att ed blk blkdef doc) (vl-load-com) (setq doc (vla-get-activedocument(vlax-get-acad-object))) (if (setq lay (mydcl "Select layer" (acad_strlsort (tablelist "LAYER")))) (progn (while (setq att (nentselp "\nSelect attribute :")) (if (= (cdr(assoc 0 (setq ed (entget(setq att(car att)))))) "ATTRIB") (progn (setq att (vlax-ename->vla-object att)) (setq blk (vla-objectidtoobject doc (vla-get-ownerid att))) (setq blkdef (vla-item (vla-get-blocks doc)(vla-get-name blk))) (vlax-for itm blkdef (if (and (= (vla-get-objectname itm) "AcDbAttributeDefinition") (= (strcase(vla-get-tagstring itm))(strcase(vla-get-tagstring att)))) (progn (vla-put-layer itm lay) (vla-put-layer att lay) ) ) ) (vla-update blk) ) ) ) ) ) (princ) ) (princ "\nType CHATTLAY to run") Quote
