KarolR Posted October 29, 2012 Posted October 29, 2012 In version 2009, in the Document Settings, tolerances tab i have set tolerances, but when i set dimensions they all come with three decimal places. I don't see where this default can be set, in the tolerances tab. Where is the standard that rules that. Quote
JD Mather Posted October 29, 2012 Posted October 29, 2012 Tolerance is not the same as precision. Set you number of decimal places on the Units tab of Document Settings. If you want this to ge the default - save this setting in your template file. Quote
