When i save the drawing it gives that message,
*Warning* Multiply owned object, handle "D2209"
i don't this is what?
plz tell me?
thanks advance:D
Please paste the line below on your command prompt, it will highlight the trouble-maker entity:
(progn (command "_ZOOM" "_O" (setq x (handent "D2209")) "")(sssetfirst nil (ssadd x))(princ))
When i paste this line below on my command line prompt
it show this message,,,
[All/Center/Dynamic/Extents/Previous/Scale/Window/Object] : _O
Select objects:
now what should i do?
That code was supposed to focus on the entity bearing that handle (highlight and zoom to it). But, for sure, this will work only for graphical entities. Seems that it not work with your entity - I never saw such identificator (Bad Entity name).
Try to paste this in command prompt and post here the result:
(entget (handent "D2209"))
now this message show that
; error: bad argument type: lentityp nil
and now i save the drawing it shows no any warning
so it is pretty cool code
thanks msasu
ohhh my God again show this warring message......... :(
Both code excerpts from above were only trying to identify the trouble-maker entity; neither will do a fix on the drawing, so cannot be the source of that temporary fix.
By the way, did you tried to run an AUDIT on that drawing?
i use audit and recover as well but warning message is constant.... :'(
I found this...
Try
(entdel (handent "D2209"))
Should delete it.
SLW210 i used this code but warning remain constant.....
I have openned your drawing and get no warning messages other than the one warning me that the drawing contains macros. I'm sorry but I am not openning up an unknown drawing and enabling contained macros.
I checked MSasu's code to find the following "offending" item
<Entity name: 7ee96408>
Command: (entget x)
((-1 . <Entity name: 7ee96408>) (0 . "BLOCK") (330 . <Entity name: 7ee910d8>)
(5 . "D2209") (100 . "AcDbEntity") (67 . 0) (8 . "0") (100 . "AcDbBlockBegin")
(70 . 0) (10 0.0 0.0 0.0) (-2 . <Entity name: 7ee910e0>) (2 . "_ARCHTICK") (1 .
but as I said above, the drawing is good here. I will leave it to MSasu to suggest whether the macro could be the cause of your problems.
dbroada when you save the drawing that time you will see the warning message after save it....
no I don't. It saves as I would expect. I can't replicate your problem so can't help.
now i don't know what i should i say.... may be its me software problem..
Well here is what I get, Macro not enabled...
_ZOOM
Specify corner of window, enter a scale factor (nX or nXP), or
[All/Center/Dynamic/Extents/Previous/Scale/Window/Object] <real time>: _O
Select objects: <Bad Entity name: BFB09408>
Command: (entget (handent "D2209"))
((-1 . <Entity name: -404f6bf8>) (0 . "BLOCK") (330 . <Entity name: -404e0f28>)
(70 . 0) (10 0.0 0.0 0.0) (-2 . <Entity name: -404e0f20>) (2 . "_ARCHTICK") (1
With Save As....
Command: _SAVEAS
The trouble-maker entity is a block that seems to don't have any instance inside the drawing. A solution that worked in my tests was to copy entire content of the drawing into a new one. The said block is retrived too, but seems to be fixed.
  • 1 year later...
I found this...
Try
Should delete it.
That worked, thanks. (of course I have no idea what was deleted?)
